Dec 06, 2016, 08:42 PM
New Product
Insight 5.8G 1080P 100mW Full HD Digital Video Transmission System
-1080P HD
- Over 5km distance with the 14db directional antenna(custom)
-Buit-in OSD
-Transmitter weight 58g only
-USD 249.99 freeshipping
Can you believe it? Isn't it a lovely baby?!
Check out more information in the video. And grab one for yourself: https://www.foxtechfpv.com/insight.html
Affordable 5G 1080P HD Digital Video Transmitter 5km range with Built-in OSD (6 min 45 sec)
Dec 06, 2016, 09:16 PM
Features:
5G FHD Digital video transmission
Input support up to 1920*[email protected],Output support up to 1920*[email protected];
Use the 5G radio technology, TX power 100mw(CE certification and FCC certification);
Ground control with the 5db omnidirectional antenna (standard),transmission distance over 2-3 km;
Ground control with the 14db directional antenna(custom), transmission distance over 5km;
Input and Output:
HDMI Input
5G WI-FI FHD Output: Android phone, Pad can be used as a monitor after connected the APP.
Anti-interference
Up link/Down link Using MIMO multi antenna technology and OFDM modulation mode, with advanced algorithms, and effectively improve the stability of the system data bandwidth and complex environment, improve the dynamic performance of the system;
Down link real-time monitoring of each channel interference state, dynamic selection of optimal channel work (up to 24 transmission channels);
supporting up to 24 devices working at the same time;
Low latency
System maximum time delay 80ms;
OSD function
Built in OSD function, you can achieve the information function with the APM pixw pix without the external OSD.
Bundled flight controller
Without any restrictions on the APM pixw APP pix built-in digital transmission.
Multiple mode and information secure
Ground side can link over two devices.
To ensure that information only through the ground side of the authorized frequency of the encryption transmission video data can be received.
Battery and charge
Ground side built-in 1300mAh large capacity battery, the device can work continuously for 2 hours, can be charged by power bank.
Sky control input voltage 5-18V
Product specification
Video input: HDMI
Support format(HDMI):720P 50fps;720P 60fps;1080I 50fps;1080I 60fps;1080P 25fps;1080P 30fps;1080P 50fps;1080P 60fps;
RF parameters: 5GHz,FCC certification
Interface(Ground control):LED, power switch, charge input, USB 2.0
Interface(Sky control):LED;HDMI input;PWM output;TTL transmission;
Material:Aluminum alloy
Power (Ground control)C 5v; Build-in battery; Watts: 6W
Power (Sky control): DC 5~18V; Watts: 8W
Size (Ground control): 69*49*16(mm)
Size (Sky control): 67*37*20(mm)
Weight (Ground control): 100g
Weight (Sky control): 70g
Transmission distance(outdoor): with the 5db omnidirectional antenna(standard),transmission distance over 2-3 km, with the 14db directional antenna(custom),transmission distance over 5km
Output delay:80ms/0.08s
Band frequency:5.1GHz-5.8GHz
Modulation mode:MIMO-OFDM
Video input:Mini HDMI
Compatible input video format:HDMI all format, up to 1920*[email protected]
Output format:640*[email protected]@60,1280*[email protected]@60,1920*[email protected] 0
Compression:HEVC High definition television broadcasting
Channels:24 channels(Automatic frequency hopping, anti-jamming)
Support devices:Phone,Pad,PC
Support system:Android,ios,Windows
Data interface:UART data transmission interface
PWM control interface:4 PWM control output, you can control the gimbal and other external devices.
Communication encryption:256bit encryption
Temperature:-10℃-60℃
Certification:FCC Certification
Dec 07, 2016, 10:07 AM
wow.. no one interested in this awesome cheap HD transmitter?
Dec 07, 2016, 12:08 PM
ive ordered one, carnt wait
Dec 07, 2016, 12:12 PM
how do you record the video on the phone ? is it with one of the two apps ?
Dec 07, 2016, 06:59 PM
It says: can connect to phone tablet and PC how do you connect to PC?
I'd be all over this if it had an HDMI output on the receiver
Dec 08, 2016, 11:59 AM
glassfox does the micro usb on the side of the reciever do video out ?
Dec 08, 2016, 09:43 PM
foxtechtech's Avatar
It is hot selling in Foxtech NOW
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Dec 09, 2016, 12:21 AM
"HOT SELLING" that's all you got to say? how about answering the questions !
Dec 09, 2016, 08:39 PM
I downloaded a recorder app from Android.
Dec 09, 2016, 08:40 PM
wifi
Dec 09, 2016, 08:41 PM
Thanks for your support.
Dec 09, 2016, 08:45 PM
Insight 5G 1080P FHD Digital Video Transmitter Footage
Insight 5G 1080P FHD Digital Video Transmitter Footage (7 min 27 sec)
Dec 09, 2016, 08:51 PM
Latency Comparation: Insight: 170ms VS Mavic: 180ms VS Inspire1: 280ms.
Dec 10, 2016, 07:37 AM
hi foxtech,
recieved my insight unit today but i think the reciever is dead, cannot see the wifi output at all, the reciever has power and data led on constantly and no wifi output. can the reciver be flashed?
