This thread is privately moderated by JohnVH, who may elect to delete unwanted replies.
Dec 05, 2016, 12:56 PM
JohnVHRC
JohnVH's Avatar
Mini-Review
Gteng T905F Unboxing Review PT1
GTENG T905F RC Racing Quadcopter Unboxing PT1 (7 min 38 sec)
Where to get one: https://goo.gl/t7C1w9
This is a really complete fpv package, the camera can be rotated up or down so you have options for how you want to view via fpv. It has really great looks, and real 5.8G fpv! That always is better than wifi fpv range.
It does all the fun stuff, flips, return to launch, headless, rates... All in a nice package. The FPV screen is easily seen outside, everything is right in reach and works great.
PRO:
- Altitude hold
- 5.8G fpv
- Spare props
- USB Charger
CON:
- SD Card a little tricky to get in the card slot
- Two different battery plugs, one common would be nice
- Camera doesnt quite to UP enough for fast forward flight
Main Features:
90 - 100W 720P HD camera:
You can use it to capture and record every wonderful moment in your life.
5.8G FPV system:
Allows real time image transmission and offers you clear and bright aerial pictures and videos.
Air pressure altitude hold function:
Improves the stability of flight, aerial photography and video recording performance.
2.4GHz control system:
Ensures the stronger anti-interference performance and powerful signal.
6 axis gyro:
Provides the best stability during indoor and outdoor flight.
360 degree rollover:
The quadcopter will flip forward / backward / leftward / rightward according to your instructions.
Specification
General
Brand: GTeng
Type: Quadcopter
Model: T905F
Features: 5.8G FPV
Motor Type: Brushed Motor
Functions: 3D rollover,Air Press Altitude Hold,Camera,Forward/backward,FPV,Headless Mode,One Key Automatic Return,Turn left/right,Up/down,With light
Built-in Gyro: 6 Axis Gyro
Night Flight: Yes
Material: ABS/PS,Alloy,Electronic Components
Kit Types: RTF
Level: Intermediate Level
Age: Above 14 years old
Connectivity
Remote Control: 2.4GHz Wireless Remote Control
Channel: 4-Channels
Mode: Mode 2 (Left Hand Throttle)
Detailed Control Distance: 100m
FPV Distance: 80-150m
Transmitter Power: Rechargeable Battery(included)
Model Power: Rechargeable Battery
Battery
Battery: 7.4V 350mAh Battery
Flying Time: 6-8mins
Charging Time (h): 70mins
Camera
Camera Pixels: 90-100W
Video Resolution: 720P
Dimension and Weight
Package weight: 0.860 kg
Product size (L x W x H): 32.10 x 31.30 x 10.00 cm / 12.64 x 12.32 x 3.94 inches
Package size (L x W x H): 35.00 x 35.00 x 14.00 cm / 13.78 x 13.78 x 5.51 inches
Package Contents
Package Contents: 1 x RC Quadcopter, 1 x Transmitter, 2 x USB Charger, 1 x Screwdriver, 4 x Spare Propeller, 1 x 4G Memory Card, 1 x Card Reader
Latest blog entry: Freewing SU-35 Maiden
Dec 06, 2016, 01:59 PM
JohnVHRC
JohnVH's Avatar
GTENG 905F RC QUADCOPTER FLYING REVIEW PT2 (6 min 48 sec)
Part two, the flying part! Its a very nice flying quadcopter, proportionate on the sticks, easy to control, altitude hold does great. It would be nicer if the camera could point UP more, in forward flight it can be tricky to see where your going if your not up high. It has great range and low latency.
PRO:
- Altitude hold
- 5.8G fpv
- Spare props
- USB Charger
- Great range
- Low latency
- Adjustable angle on camera
- Good flight time
- Nice big screen, easy to see
CON:
