Dec 03, 2016, 11:14 AM
IKKI's Avatar
2.4G 8CH Micro Frsky D8 Compatible Receiver With PPM SBUS Output
2.4G 8CH Micro Frsky D8 Compatible Receiver Support PPM SBUS Output
Since a few days I received this receiver I had ordered recently, I decided to install it on a 130, the conditions are excellent. Small and lightweight with a very clear signal. Also good compatibility with radio DEVO 7e with mod.
Frsky receiver -2.4G 8CH Micro Frsky D8 Compatible Receiver With PPM SBUS Output from Banggood.com (2 min 12 sec)
affiliate link
Description:
Item Name: 2.4G micro receiver
Channel: 8
Weight: 1g
PPM Output: Yes
Operating Voltage: 5V
Antenna Length: 30mm
Dimension: 11mm*23mm
Control Range: 400m
Compatibility: Compatible with Frsky D8 series transmitter
How To Bind:
1, Use soldering iron to shorted solder joint of BIND,the supply power to the receiver,blue LED blinks fast means entering the binding mode.
2,Press and hold the binding button on the transmitter, in the meantime,turn on the transmitter,wait about 1 second,the blue LED stay on,means binding has succeed. Disconnected the solder joint of BIND.
3, Disconnect the receiver power supply,turn off the transmitter,re-supply power to the receiver,finally turn on the transmitter.
4, Blue LED blinks fast means receiving signal,blue LED light turn off means no signal.
Package Included:
1x 2.4G 8CH Micro Frsky Compatible Receiver
Jan 08, 2017, 03:34 PM
can you confirm that is working with 1s brushed quads?
range 3.5-4v
Jan 08, 2017, 07:08 PM
Fan of just about anything RC
SoloProFan's Avatar
range 3.5-4v
This receiver was used on some brushed 1S FPV quads in the Tiny series, before the all in one FC + RX combo boards appeared.
