Canterbury J #590 "Shamrock V" - Page 3 - RC Groups
Dec 05, 2016, 01:07 PM
Modeler/ Historian
Stephen Vick's Avatar
After I have sanded everything flush and ready for the deck, I will seal the beams with epoxy thinned about 25%. I thin the epoxy with denatured alcohol
Dec 05, 2016, 01:37 PM
Kevin Gault
poltergeist's Avatar
Coming along nicely Stephen. Yea the sheer strips are a bit tricky aft with the way the aft quarter of the hull tapers.
Nice job!
Kevin
C-J #551
Dec 05, 2016, 02:19 PM
Modeler/ Historian
Thanks, I am really enjoying this build so far.
Dec 06, 2016, 02:39 PM
Modeler/ Historian
Ready for sealant
Stern pieces , and shroud doublers in place. Block sanded and ready for sealant. I will use epoxy thinned 25% with denatured alcohol.
Dec 08, 2016, 09:13 AM
Modeler/ Historian
Fitting the deck
I've made a template using printer paper.I laid the paper directly on the deck framing and traced it with a sharpie. The deck will be cut from 1/32 birch plywood
Dec 08, 2016, 09:36 AM
Service First
I'm about the same place.
Waiting until I get my winch and radio board set up and installed before I install the deck beams and deck. I did make the template, no clue what I'm doing for the deck yet. Can't decide between something quick and nice, it's a race boat not a shelf queen or I have a pile of teak and it would look really nice with a teak planked deck......
Dec 08, 2016, 12:00 PM
Modeler/ Historian
Actually I'm installing my rudder servo and winch mounting before I lay the sub deck. But, I want to cut and fit it ASAP so I don't have any fitting problems later (with all that gear in place ). If I had a bunch of teak on hand I would certainly use it. Just my opinion
Dec 08, 2016, 04:33 PM
W Kuhns
BillKuhn's Avatar
Stephen. Are you going to use the drum system that Hans has in his boats.? So simple but great!! Uses an arrow shaft connected to the drum winch and a block. When he needs to service it. I believe it's just a Couple screws and it comes out in one piece. I was going to do that with the big boat but by someone's graces. It ended up with an arm.
Dec 08, 2016, 04:34 PM
W Kuhns
BillKuhn's Avatar
John if you are doing a drum like hans. I have a nice carbon fiber arrow shaft if ya need one. Also have an older drum winch servo it's pretty fast and wicked powerful. Not real huge either.
Dec 08, 2016, 05:20 PM
Service First
I'm all set with arrow shafts, I'm sort of an archery instructor.
I think I'm ordering a Hitech like I have in the Star, I need to get transmitter batteries and a couple of other things, just been putting off placing the order. Guess it's time
Dec 08, 2016, 06:24 PM
W Kuhns
BillKuhn's Avatar
Jack of all trades and sports I see.
Dec 09, 2016, 12:23 PM
Modeler/ Historian
I plan to use a Hi Tec arm type sail servo The reason is speed and simplicity.
Dec 09, 2016, 08:27 PM
W Kuhns
BillKuhn's Avatar
Cool. I will say both points well taken especially simplicity. However if you ever get an RMG speed is WOW!!! Never had one till stars and steipes. Wholly cow. I really can't afford to buy them but the boat came with it. Amazing how powerful and fast they are. However I really really like arms winches as well
Dec 09, 2016, 10:53 PM
Modeler/ Historian
Rudder install
Rudder / stuffing tube installed tonight. Epoxy thickened with micro balloons holds the stuffing tube. Servos next!
Dec 10, 2016, 10:43 AM
W Kuhns
BillKuhn's Avatar
Nice job.
