Youbi XV-130 130MM FPV Racer - RC Groups
This thread is privately moderated by SeByDocKy, who may elect to delete unwanted replies.
Dec 01, 2016, 01:21 PM
SeByDocKy's Avatar
Mini-Review
Disclaimer (inspired from SP) Product specifications and quality may vary at the manufacturer's discretion, and are beyond my influence. I cannot guarantee you will get a product that performs exactly the same as seen and described in this review. Please, no savage affiliate links! By the way, in contracdiction with some other reviewers, I open a new mini-review thread ONLY when I have the machine in hand ....
INTRODUCTION
Here is a more or less a direct clone of the Rotor-X Atom V2 with the Youbi XV-130, a compact 130mm brushless racer with strong 1306 motors and 20A BLheli_S ESC. The direct inspiration of the Atom V2 is obvious with 3" quadri-blades props. Let's compare/highlight the difference/improvement of the Youbi XV-130 versus the orignal non-chinese version. The first main avantage of the youbi is clearly the price... close to three times more cheaper.
BOX CONTENT
+ 1 x Youbi XV-130
+ 4 x Spare props (2 CW, 2 CCW)
+ 2 x Receiver plugs (1 for PPM, 1 for SBUS)
+ 2 x Battery velcro straps
+ 1 x Instruction manual (English/Chinese)
OVERVIEW
As said previously, the copy with the Atom V2 is clear, the type of profiled canopy. Here the canopy's plastic quality is correct, but won't resist to a massive crash. On top, a 5.8G linear antenna installed vertically.
In comparaison with Tarot TL130H1, where 1104 more are prefered.
-Front view
-Side view
Any visible port to tune settings for the SPF3 board... no choice you will have to remove the top canopy section
A basic mod consists in create a direct USB port access....
-Rear view
A novolty,for the Youbi XV-130 instead of JST or XT 60 connector, we have here a XT30, smaller and lighter connector.
-Upper view
The gap between the canopy and props is very narrow. 3-4mm for front and even less for the rear section
It means, that after each crash, you will be to check of arms are not bent since despite 2mm of section, there are still flexible.
To hold your receiver's antenna, you can drill small holes through the canopy
-Bottom view
A unibody lower plate of 3K carbon of 2mm of thickness.
Be aware, the arms remains a little bit flexible. If you break an arm, you will have to disassemble everything.
-Weight
With a 4S 500mAh LiPo, the total weight don't exceed 190g
Motors
Strong 1306 motors, 3600 Kv are installed, 10g each
Shaft section is 4mm (like the XK X251)
In comparaison with 1104 tarot motors
Props are 3" models quadriblades, to more precise some 3030 model
LiPo
I opted for a light and compact 4S 500mAh LiPo directly equiped of the XT30 connector
IMHO, the best choice should be a 600-700mAh model still in 4S.
Camera module
Announced to be a 600TVL CMOS PAL camera with 100 degrees of FOV. As you can see, the camera is installed on a 3D printed suppert inclided of 15 degrees approximatively.
No possibility to tune the uptilt angle unfortunatly for agressive FPV flights, the default angle is not enough....
More the light sensitivity is really poor and in practice, you can be completly blind face to the sun. The same symptom as for the Tarot TL130H1 ... Probably no associated WDR.
A raw video sample
Youbi XV-130 raw FPV sample (1 min 58 sec)
For high throttle inputs, some jellos/vibration are noticable. maybe by inserting some foam elements around the camera, the effect can be reduced. Better PIDs/TPA settings should help too.
If you don't like the default 100 degrees for the FPV, the lens thread is in M7 format, so easy to find a replacement candidate
Video transmitter
A unique white button nearby the RP-SMA connector permits to select the frequency band (5 bands supported), the frequency and output power mode.
To enter into the band selection, press 2s the button. Then band letters should cycle. When you favorite band is selected, short press the button.
Then by short pressing, you can select one of the 8 internal frequencies. To save the configuration, long press 2s the button. A small red dot should appear in lower right position.
To select the output power, you have to keep pressed 6s the button. Then pressing the button 3 digits are displayed. 1 for 25mW, 2 for 200mW and 3 for 400mW. One more time press 2s to save the setup.
SeByDocKy's Avatar
Disassembling
Remove the two M2 hewscrews on top and open it by rear side first
after the installation of your favorite receiver
For me a Superior Hobby FrSky D8 SBUS SRP8 model
the microUSB port of the SPF3 board on the right side
Below, 2 free UART ports where you can plug an OSD board if you want
The left side welcomes the receiver port. Two cables are given either for PPM or SBUS connexions
The RP-SMA connector is mounted vertically. During a major crash, the connector can be damaged
Maybe by adding some hot glue around, it could help to secure the system
The bottom face of this upper board is nothing else than the SPF3 section.
You can notice the absence of a buitlin buzzer... desipite to be a must to have for such compact size.
The inner board is the 4-in-1 ESC/PDB board.
ESC are rated 20A and supporting BLHeli_S technology. Be aware by default, oneshoot 125 is selected in betaflight, not multishoot.
If you select multishoot (advise), you will need to change the minimum throttle to 1040 and minimum command to 990. Maybe we can regret non-individual ESC but the system would have been more heavier too.
UNBOXING, ANALYSIS, CONFIGURATION AND FIRST DEMO FLIGHT
Youbi XV-130 unboxing, analysis, configuration and demo flight (Courtesy Banggood) (31 min 5 sec)
FIRST USAGE
CONCLUSIONS
The positive points of the Youbi XV-130 is clearly the1306-BLheli_S ESC combo offering in practice a huge amount of power for such compact size. The SPF3 FC offers also super fast PIDs loop for ultra smooth flights. Announced to be sold around 130 USD, the price represents also the massive argument in favor of the Youbi. Anyway, this product is far to be perfect.... especially the FPV camera is a really poor light sensitivity where you can be almost blind for under-exposed areas. If you are interested by this machine, it's strongly advise to upgrade the FPV cam asap. The flexibility of arms seems to introduce also some vibrations at high throttle inputs. Better TPA ajustements and probably introduction of foam should reduce this artefact.
PROS
+ Design cloning the Rotor-X Atom V2
+ 20A BLheli_S ESC
+ SPF3 board
+ Flashed with last Betaflight
+ Strong and powerfull machine
+ 3 VTX output powers (25mW, 200mW, 400mW)
+ 3K Carbon based
CONS
- Poor light sensitivy of the FPV camera
- No direct USB access
- No builtin buzzer
- FPV camera uptilt angle blocked
- Frequency list table partially false
- Vibrations for high throttle inputs
- Flexible 2mm arms
- 5.8G Linear antenna
- (no OSD)
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thank them for this attitude.
You can find it actually for 28USD at http://www.banggood.com/Cheerson-CX-10C-CX10C-Mini-2_4G-4CH-6-Axis-RC-Quadcopter-with-Camera-RTF-p-989909.html
Apr 15, 2017, 07:19 PM
I think i found my new MASTER i hope
Sir , hello.
i am WannaDuino ( SiSiXL ) aka Simon from the Netherlands, and yeah i am a newbee
i just have my first quad with a NAZE 32 board, and yes then you need to go to cleanflight or Beta.
i used cleanflight, without ANNY idea what to do.
1x direct BULLSHIS, could not hook up, becausei have clean 2.0 did not know that was an issue, but read i had to FLASH it. so i did, finaly i could go in to cleanf.
i know i did a few things good, set it to brushed and some other things i seen on YT, but it flys a little, HOVERING lets say that, but it drifts and yaws i think. but ???
i seen it can maybe with the transmitters end points or so???
HELP
then this
I also have a TARANIS QX7, NEVER had one only TOYS, in the hospital, ( other story ) 2 years long even )
so i could only play a bit from out my bed,
i am at home now revalidating, HAPPYYYYYY ME..
I need help and guidence how to set it up GOOD and how i can set the transmitter.
i already have some auxes 1 for arm that works, i think but it is on a 3 pos switch aux1
and 3 modes, i only want angle, for now.
and yes i have also the DROP OUT OF THE SKY BS, battery thing i seen..
so do you say i must solder that wire on the bottom??
that is basicly it, a noob that needs a bit of help and searches for a master...
i am willing to pay if i must, but help me away with a vid or links,
i am scared to blow it up,
because aalready when i ONLY sad it down on the table, a power reguletor flew of of the board, BAD SOLDERING from eachine. pfffff BAD man
so i will be
mail me please back not here i do not come here often but wil be soon. this is an awesome place with al the knowladge we need iseen, good vids man got to say that.
wannaduino@gmail.com
New Product Youbi XV-130, another 130MM FPV Racer but on steroids SeByDocKy Micro Multirotor Drones 1101 Nov 29, 2017 01:22 PM
