This thread is privately moderated by montis, who may elect to delete unwanted replies.
Dec 01, 2016, 01:38 AM
New Product
Racerstar RF2205 (RF2205S) review
I have recently received a set of Racerstar RF2205 2300Kv motors from Banggood for a review. Motors came well packed in a carton box. Package includes motors, bullet type prop nuts and M3 steel screws. Motors are sold only in packs by 4 (2 CW + 2CCW). It would be great if Racerstar would offer an option to buy single motor. This will enable buying a spare one or a replacement for broken/bent/burnt motor. Personally I would suggest to sell only CW shaft thread version of these motors with a prop lock nuts. Lock nuts hold props hard enough on CW and CCW rotation motors there is no real need of different threads. Benefit of this is versatility of motor use every motor can be either CW either CCW, no need to have 2 spares and in case of RF2205 - 4 spares.
Description:
Comes in packs by four
Motors have solid hard steel shaft. That is one of the reasons why they are heavier than BR2205.
Description:
Solid steel shaft and steel screws
There are a lot of cut-outs for air intake on the lower part of the stator.
Description:
Cutouts for air intake and shaft nut
Also notice that shaft is locked with 2mm hex screw instead of the C-clip. Dont tighten them too much, because plastic washer starts to rub against the bearing and introduces some drag to motor motion.
Inside of the motor - the bell (rotor) is reinforced and well balanced. The windings are made of multi-stranded copper wire. Magnets are curved and N45SH strength grade.
Pros
Steel shaft harder to bend
20 AWG soft silicone wires
Cut-outs in the bottom plate for air cooling
Shaft is locked by hex screw instead of C-clip
Curved magnets, N45SH
Reinforced and balanced bell
Cons
Sold in packs by 4 pcs only
Bullet type prop nuts
Build quality is high. Thrust results show high static thrust power, one of the highest in their class. My personal opinion - they can be compared with Emax RS2205.
Here is my humble video review of these good motors:
Racerstar RF2205S 2300KV motor review (7 min 16 sec)
Static thrust tests to come later...
