This thread is privately moderated by mahowik, who may elect to delete unwanted replies.
Nov 30, 2016, 01:11 PM
MahoWii 2.4 was released
Hi guys!
https://github.com/mahowik/mahowii
Here is the latest revision of my favorite hobby project based on Multiwii project.
In two words: it's pretty stable, improved and extended version of Multiwii.
Changes:
- INS (inertial navigation system) integrated with GPS and Baro
- predefined PIDs to fly out of the box for frames 330 and bigger
- completely different precise althold integrated with INS
- right altitude management by setting desired vario (vertical speed) with throttle stick
- single PID controller for hovering and altitude management
- stable hovering trottle estimator/corrector by I-part of alt PID controller
- smart land detector
- reduced effect of air-cushion to avoid incorrect raw baro values and jumps near the ground accordingly (integrated with INS)
- controllable by desired vario (vertical speed) landing
- new SAFE_ALT_DURING_AH define. It helps to protect descending less than specified in define altitude. Activated when SAFE_ALT box activated in GUI.
- precise, rapid, sensitive to external perturbations (wind, pushes) GPS-INS position hold (INS_PH_NAV_ON define)
- possibility to fly with activated position hold and stop at predicted point on stick release (tunable by Pos-I value at GUI)
- wait for target altitude at RTH and WP navigation
- skip whole RTH cycle if distance less than RTH_RADIUS meters and make a landing
- safe and soft takeoff on RTH and WP Navigation
- for safety prevent arm if RTH or NAV switched on
- new auto config defines for UBLOX and MTK3339 modules
- precised gyro calibration + 3 axis acel calibration + filtered mag calibration to avoid min/max noise values
- frsky telemetry adopted for er9x-frsky TX firmware
- 50hz PID output for althold, gps modes
- cycle time independent final PID controller
- optimized math
- a lot of fixes
For more details please read release_note.txt, see config.h and also here http://forum.rcdesign.ru/blogs/83206/blog22332.html
Tips and tricks:
- for INS it's better to use u-blox modules with revision from 6 to 8 (although 7th was not tested). With MTK modules position hold is less precise but in general it's ok also, where PID parameters has to be ~20% less for its.
- for INS it's good to have calibrated accel in 3 axises with +/-512 for each axis with error +/-(1-3)
- for configuration the best tool is https://play.google.com/store/apps/d....ezio.multiwii
- for this release arduino 1.6.7 was used https://www.arduino.cc/en/Main/OldSoftwareReleases
- before 1st upload clean eeprom http://forum.rcdesign.ru/f123/thread...ml#post4263236
This firmware was optimized for AIOP (ALL IN ONE PRO Flight Controller), or other with Atmega1280/2560 + mpu6050 + ms5611 + hmc5883 (but take care about pinout). But you can try to play with other sensors also.
Videos from my friend's youtube channel:
https://www.youtube.com/user/artnesterof/videos
Blogs:
- http://www.multiwii.com/forum/viewtopic.php?f=8&t=7877
- http://forum.rcdesign.ru/blogs/83206/
Enjoy!
To support project feel free to click [Donate]
Dec 16, 2016, 02:55 PM
Does not work for Baro ..readings in GUI always 0
Hi..any tip?
Its not important what board i chose, alsways same. If i use standard Multiwii 2.4 its ok for baro readings.
Dec 19, 2016, 10:20 AM
Hi,
Altitude is calculated at INS after ARM/start where before start it's calibrated to zero.
I.e. just make an ARM and you will see that alt is not zero.
Dec 25, 2016, 02:16 PM
I understand what you say but I cannot make the ALT / Baro value reset at arm with your version. It works nice with the standard Multiwii 2.4
You can download and test my version..http://3600kongsberg.no/
Jan 25, 2017, 07:07 PM
event horizon
OH BOY!! can't wait to try it!! Have a new EZ black on the way and I have just the hex frame for it. I'll be back.
Jan 27, 2017, 10:01 PM
AlouetteIII's Avatar
Hey Alexandr - great work - !
Its running well on PARISv5r3 atm using an M8N
Jan 28, 2017, 12:34 PM
Thank you guys!
Waiting for videos from you
Jan 28, 2017, 02:10 PM
event horizon
Originally Posted by mahowik
Thank you guys!
Will do as soon as I get it in the air.
Feb 17, 2017, 11:27 AM
event horizon
Working on down loading the needed stuff now he copter I on 2.3 and is flying/ring fine on default PID's BUT s a disclaimer two motors are running hotter than he other two. I have checked the kv and the ESC settings nominal results. The copter being controlled by a Futaba 14 but it will not arm with just yaw right. It requires a long list of commands and then only starts on two motors, the ones that are running significantly hotter than the two that are running about a 105*F. Reboot the system after the two motor start and it still requires ten stick moves to arm but than all 4 motors run and it fly's as if there is nothing wrong. Futaba?
Feb 19, 2017, 08:34 AM
event horizon
Must have something wrong all that downloaded was the Mohawii file but there is nothing else like the config h. I did down load Arduino 1.6.7 and MW 2.4. I set the parameters in MW 2.4 and verified the sketch and it worked. Is Mohawii a file that is supposed to be pasted into 2.4?
Feb 22, 2017, 07:32 AM
event horizon
Any thought on what I got going wrong?
Feb 23, 2017, 11:00 AM
to download sketch:
1) in linux type: git clone https://github.com/mahowik/mahowii.git
2) in windows:
- go to https://github.com/mahowik/mahowii
- press "clone or download" -> "dowload zip"
- unzip "mahowii-upstream_shared" folder and rename it to "mahowii"
then open mahowii.ino at Arduino as ususal
Mar 16, 2017, 06:00 AM
event horizon
to download sketch:
2) in windows:
Thanks been over whelmed with work the last couple weeks hopefully have some time this week end to work on this.
Mar 19, 2017, 06:49 PM
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
That's interesting, might worth porting it to the Quadrino Nano for a try
Apr 22, 2017, 09:20 PM
Dialfonzo's Avatar
No interest ?
Discussion MahoWii rev 2.4 was released mahowik Multirotor Drone Electronics 0 Nov 30, 2016 12:39 PM
