X4 AC Pro Questions - RC Groups
Nov 27, 2016, 07:35 PM
PGR
PGR
Low AltiDude
PGR's Avatar
X4 AC Pro Questions
The manual for this charger is unclear about the NiMH/NiCd charging modes. One possible interpretation is that the Charge mode is a constant-current mode and the Auto mode is the peak-detect mode. Can you clear this up? Can you explain the difference between the Charge and Auto modes in a little more detail?
Pete
Nov 28, 2016, 11:09 AM
Xpress..'s Avatar
Pete,
Charge mode will charge at the current you set, Auto mode will charge at a rate the charger determines to be the best rate within the current rate you set.
Nov 28, 2016, 02:22 PM
PGR
PGR
Low AltiDude
PGR's Avatar
So they're both peak-detect cycles based on the -deltaV we set in the setup menu?
Pete
Nov 29, 2016, 11:51 AM
Xpress..'s Avatar
Yes, NiXX functions of the charger both use Delta peak.
