Jan 02, 2017, 04:10 AM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
There is a guy on youtube beating the crap out of his kit showing how tough it is. I think it would be the best available at present.
Latest blog entry: A bit about me
Jan 02, 2017, 05:20 PM
Originally Posted by Grantham Kid View Post
Yes JoeMama (But you could have guessed that couldn't you)
I have one coming for review but won't see it this side of Christmas now. It is FPV equipped.
Interesting that kbirds specs say a 200 mw VTX but the one I am getting specifies a 600 mw VTX.
GK
Have you received yours yet GK?
Just curios I ordered mine just before Christmas and have not seen much movement on the tracking I suspect it is in transit(Ship or Plane)
Jan 02, 2017, 05:29 PM
No VT I haven't as yet. The tracking has been totally useless lately. I got a glider the other day that was supposed to be still in Hong Kong. Nice surprise though. :-)
Jan 04, 2017, 12:01 AM
According to the tracking update today I will see mine tomorrow, just in time to maiden on the weekend
Jan 04, 2017, 01:21 AM
lucky sod :-)
Jan 05, 2017, 10:49 AM
Built up my Sky Shadow kit and it will fit a 22oo 3s battery. With a EMAX 2205-2300 "Red bottom" motor and 20a esc (need to go to a 30A as that motor is power hungry)
Haven't had a maiden yet, but something I did notice it that it was designed to balance with the GoPro installed. I had to add 80g of lead to the camera compartment (with the 2200 3s battery) to get it to balance at the 125mm mark.
If I fly with a HD cam, I can pop the lead out and just install the camera. But you are going to have a hard time balancing if you plan to fly without HD recording.
Jan 05, 2017, 04:20 PM
All good information thank you.
Jan 05, 2017, 04:49 PM
I put my PNP together last night, found a bit of the detail was lacking around the wiring but the big one is they I cant find the CG on the docs. Based on the comment above I assume it is 125 mm
Jan 05, 2017, 05:59 PM
Read the specs here. It says 125 mm. In the first assembly schematic it shows it as well if you look close.
Jan 05, 2017, 06:24 PM
Can you go any bigger than 2200 to fly without an HD cam. I have a runcam 2 but that won't be a very good fit.
I have the PnP version en-route. Planning on swapping out the camera and gyro board for a Foxeer HS1177 and Omnibus F3 running iNAV
Jan 05, 2017, 08:08 PM
The kit arrived today from Banggood. The wing tips on trailing edge of both halves (not the winglets) were bent due to the shipping box being crushed. I noted that in the arrival confirmation.
I am researching now how to get the shipping rash fixed.
Jan 05, 2017, 10:15 PM
The zippy compact 2200 3s I have length wise is wall to wall in the bay. That battery is 114mm long. I would say the bay is then 115mm wide.
Jan 06, 2017, 12:13 AM
Does the accessories that come with the PNP any good specially for FPV?
As YouTube review of this wing is not very promising.
Jan 06, 2017, 02:37 AM
I wish I had ordered the kit - the CMOS camera will be no good, the vTX has DIP switches, I'd only put a proper FC in this wing along with GPS (so won't be using the board).
The motor, esc and servos aren't worth the extra.
Jan 06, 2017, 03:09 AM
Thanks for the info. Zippy Compact 2200 3S 35C - 181g 114x34x21mm
So I guess something like these may be good batts for this wing:
Zippy Compact 2450 3S 35C - 210g 114x34x25
Nano-tech 2200 3S 45C - 201g 112x36x26
Turnigy Graphene 2200 45C - 201g 107x35x28
Then there's 4S to consider. I'll probably start on 3S and see how she goes.
New Product [New Arrival]Reptile S800 SKY SHADOW 820mm Wingspan FPV EPP Flying Wing RC Airplane BG Tobey FPV Aircraft 257 Today 06:05 PM
New Product C1 Chaser 1200mm Wingspan EPO Flying Wing FPV Aircraft RC Airplane KIT - $65 lmpuIse FPV Aircraft 169 Feb 19, 2017 03:04 AM
New Product DW HOBBY Rainbow Ⅱ Flying Wing 1000mm Wingspan EPP FPV RC Airplane KIT - $28 lmpuIse Flying Wings 5 Dec 10, 2016 01:06 AM
Discussion Skywalker X2 X-2 Mini FPV Flying Wing EPO 950mm Wingspan RC Airplane PNP TheMadCADer Electric Plane Talk 1 Oct 03, 2016 02:46 AM
Wanted Windlord. Flying wing kit Or any Flying wing kit Joe Pierson Aircraft - Sailplanes (FS/W) 11 Aug 08, 2016 01:46 PM
