Help!
Controller syncs Drone won't take off
Greetings,
I bought a Propel Sky Master Drone. When I plug in the battery the lights begin to flash and then once I turn on the controller they go solid (as they are suppose per the manual) I believe the 2 are now synced. At this time, I can't get the drone to do anything. I did however download the APP for the drone and I am able to connect to the drone via wifi and control the drone with my phone (not very well..lol) So it takes off and flies fairly well with the phone, but I want to use the controller. Any thoughts?? Also, Steps tried: 1) Remove battery turn off controller,. Replace battery, turn on controller. Still syncs but drone unresponsive 2) All same kind of Batteries (energizer) in the controller. Controller shows 100% battery 3) Tried changing modes (From 1 to 2 only) Manual says it can go in to mode 3., but I have been unsuccessful Thanks in advance. ~Brian |
Reason: Adding previous diagnostic steps
Hello Brian! Are you sure you paired the drone with the controller? To do this; turn on the drone and place on flat surface, then turn on the controller, then slide the throttle stick up and down a few times. This should make either an audible beep or make the lights blink differently, then you should be ready to fly. Hope this helped!
If you have your Sky Master Synced then you can pull both controls down and to the outside and the props spin but doing anything else gets you nothing or a beep, Try this, pull the controls down and to the outside , let call this Neutral, keeping them down move both to bottom center you will notice it keeps going in neutral, so now , like i first did Push both controls forward the speed will Jump your Drown will take off oh step to the left or its going to run into you, have fun.
