Ardupilot on OpenPilot Revolution - Page 4 - RC Groups
Dec 13, 2016, 03:54 AM
Originally Posted by night_ghost
PPM fixed
great news night_ghost
I will try it as soon as possible but I'am afraid not before the week end
Dec 13, 2016, 04:19 AM
Oplink rfm22b chip (Si4432) compitible with si10xx used in 3dr sik radio. Basically si10xx is si4432 + mcu in one package. I think it is possible to port and merge sik firmware (which runs on mcu) to main ardurevo firmware.
I will look into it as my revo arrived.
Maybe we should not use oplink pins for anything else? 3 uart is already enouth, imho.
Dec 13, 2016, 08:48 AM
RevoMini don't has RFM, moreover there are 3DR modems which lighter than RFM!
3DR
OSD
GPS
DSM
SIM800 as GSM modem
Dec 13, 2016, 09:37 AM
But full revolution board has it build in.
It is logical to support it.
Dec 13, 2016, 10:05 AM
May be, if anyone will do it ever.
Dec 14, 2016, 06:35 AM
I am looking into you code...
I see revo specific defines in arducopter/config.h. And there are no such def in arduplane folder. Arduplane is supported?
Dec 14, 2016, 06:40 AM
Yes but all debugging is done with Copter because copter is most demanding to hardware. Headers in Copter/Plane are optional and only need to project with no optimizations (-O0) can fit to flash
Dec 15, 2016, 05:24 AM
This morning, before coming to work I had the time to do some test.
I flashed the new bin and from apmplanner2 I was able to do all the calibration (acc, mag and RC) so PPM issue is resolved. Thanks night_ghost.
Then normally I do some "low altitude flight": on the floor with little bit of throttle I do little movement on the pitch / roll to see the quad moving front / back /left / right.
When I did this last test this morning with just a little bit of roll or pitch I have the quad suddenly flipped upside down.
I double checked the motors and propellers with this picture (QuadX):
http://ardupilot.org/copter/_images/...X_QuadPlus.jpg
Maybe I am doing some stupid mistake that I don't see.
Dec 15, 2016, 06:21 AM
This is most likely due to the difference in the numbering of motors in Arducopter and OpenPilot, for now order as is from ArduRevo. In a few days I'll try to check and change motor order to Arducopter's one.
UPD. Like here?
Dec 15, 2016, 07:09 AM
UPD. Like here?
Yes like in the video.
Dec 15, 2016, 07:57 AM
This is definitely motor order. Tomorrow I'll fix it
Dec 15, 2016, 08:08 AM
In fixed wing setup motor/servo order also changed?
Dec 15, 2016, 09:38 AM
Not changed - but simply stays as it was in OpenPilot, so pls look to OpenPilot documentation
Dec 15, 2016, 09:56 AM
So if I connect the motor as in attached picture it should works OK
Dec 15, 2016, 10:00 AM
I can not guarantee but probably yes. But I have much bigger plans for it
