New Product
[New Arrival]Reptile S800 V2 SKY SHADOW 820mm Wingspan FPV Flying Wing RC Airplane
Reptile has upgraded to S800 V2
PNP:https://www.banggood.com/Reptile-S800-V2-SKY-SHADOW-820mm-Wingspan-Gray-FPV-EPP-Flying-Wing-Racer-PNP-p-1184900.html KIT:https://www.banggood.com/Reptile-S800-V2-SKY-SHADOW-820mm-Wingspan-Gray-FPV-EPP-Flying-Wing-Racer-KIT-p-1184901.html ![]() ![]() Description: Brand Name: Reptile Item Name: S800 V2 SKY SHADOW Material: EPP foam Color: Grey Wingspan: 820mm Length: 405mm CG:125mm behine the nose Motor: 2205 2300KV Brushless ESC: 30A Servo: 9g*2 Propeller: 6045 Skill Level: Intermediate Age: 14+ Weight:170g(Without electronic equipment) Packing Size: 450x270x130mm Specification of Camera: Case Size: 25mm*25mm Weight: 9.5g Total Pixels: PAL - 1020H * 596V (610 thousand images), NTSC - 1020H * 508V (520 thousand images) Active Pixels: PAL - 976H * 582V (570 thousand images), NTSC - 976H * 494V (480 thousand images) Signal System: PAL/NTSC Resolution (horizontal center): 700TVL Video Output Amplitude: 1.0Vp-p/75 Automatic Gain Control: 0.25/0.50/0.75/1.00 Electronic Shutter: 1/50 (1/60) - 1/100000 seconds Gamma Correction: 0.45/1.0 Synchronous Mode: Internal synchronization Lens: Standard 2.8mm lens Operating Voltage: DC12V (wide voltage, 5V-12V can work normally) Operating Current: 70mA Operating Temperature: -20 DEG C, --60 DEG C Humidity: 0% ~ 98% Features: Upgraded V2 version,with improved fuselage material hardness. Using the new custom flight control, lighter weight, power board wiring more convenient. Built-in 5V/3A and 9V/3A two power output, filter the current clutter, eliminating the video signal clutter interference. High quality, fine workmanship Streamlined design, high speed and low wind resistance Anti-shock,anti-impact,stable flight ---------------------------------------------------------------------------------------------- Hello guys, Here is a new one- Reptile S800 SKY SHADOW 820mm Wingspan FPV EPP Flying Wing PNP[With FPV System] http://www.banggood.com/Reptile-S800-SKY-SHADOW-820mm-FPV-EPP-Flying-Wing-RC-Airplane-PNP-With-FPV-System-p-1108534.html KIT: http://www.banggood.com/S800-820mm-Wingspan-FPV-EPP-Flying-Wing-RC-Airplane-KIT-p-1108279.html ![]() ![]() Description: Item Name: S800 RC Airplane Material: Black EPP foam Wingspan: 820mm Length: 405mm CG:125mm behine the nose Weight:170g(Without electronic equipment) Packing Size: 435x270x30mm PNP Version: Features: EPP foam construction, durable and lightweight High quality, fine workmanship Streamlined design, high speed and low wind resistance Anti-shock,anti-impact,stable flight Comes wi 3-Axis flight control ensures a more stable flight 200mw image transmission enables real-time image transmission 700TVL camera gives you a clear flight footages and makes you enjoy the fun of FPV See more:Click here. Hey, what do you think of it? ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Christmas sale: http://www.banggood.com/2016xmaswish.html?utmid=1209&gasoure=top-logo-2016xmaswish CyberMonday: http://deals.banggood.com/deals/edm/topic/CyberMonday2016.html?utmid=1170 |
Now is in pre-sale.
PNP[With FPV System]: 1-10: US$99.99 http://www.banggood.com/Reptile-S800-SKY-SHADOW-820mm-FPV-EPP-Flying-Wing-RC-Airplane-PNP-With-FPV-System-p-1108534.html KIT: 1-10: US$54.99 http://www.banggood.com/S800-820mm-Wingspan-FPV-EPP-Flying-Wing-RC-Airplane-KIT-p-1108279.html |
Nice looking wing! I like the fact it has all needed bays for VTX, RX. Also there are slots for FPV camera and gopro. Absolutely FPV ready!
Servos installed correctly - perpendicular to elevons. It should come with motor mount, servo push rods, additional bay covers and a PDB (!?): I would like to go long range FPV journey with this wing ![]() |
