Magazine
Hangar
Jay B. Scott's blog
Build Log
Finishing the Bamboo Bomber--Entry 16
This thread is privately moderated by
Jay B. Scott
, who may elect to delete unwanted replies.
Nov 21, 2016
, 09:12 PM
#1
Jay B. Scott
Jay B. Scott
Build Log
On my way to rough-balancing this bird, it looks like I need to post some things in between.
Below are four pix that will show how I had to manipulate my motors.
Images
View all Images in thread
The Rimfire 10 motors had to have their shafts reversed for the type of spinner I'm using. Their shafts are indeed reversible, having three flat spots ground in. I used a small section of 5/32 " music wire to displace them.
I needed 5/8" of stand-off to bring everything out to the front of the cowl. I used a square piece of 1/2" poplar and one of 1/8" plywood in combination, drilling to match the inner holes in the X mount. My replacement M3 screws were 25 m
It took 3 washers at about 1/32" thickness each to get the motor centered. I supported the surrounding two X mount arms with one washer each. The lines at the center were drawn in Photoshop Elements to show that I'm close enough for my own liking.
I did a screen shot while in Photoshop Elements to show you all the little black box that says the angle of the prop is at -178.5 degrees, which makes the thrust on both sides offset to the outside by 1.5 degrees. Port = pusher, Starboard = tractor.
Return to Jay B. Scott's blog
RCGroups Message
Cancel Changes
The following errors occurred with your submission
Okay
Posting Quick Reply - Please Wait
Show Printable Version
Email this Page
