This thread is privately moderated by Nerdboy, who may elect to delete unwanted replies.
Nov 19, 2016, 06:01 PM
Pod version of the EDGE100X with 1306 or 1104 motors
Here are two builds i made.
Description:
Their size is 10cm motor to motor.
I wanted to share them as it is the smallest size you can do with non-overlapping 3" propellers.
Both are very light and have an awesome thrust/weight ratio and are really fun to fly little beasts.
The carbon frame is the Edge100x you can find on armattanproductions.com, designed by Nedimcan Bodur.
I designed the pod and printed it in PLA.
First one has Emax 1306 4000kv motors, littlebee_s 20A, HQProp 3x3x4 props, a Piko BLX with a fpvhobby Vtx and a lemonRx sat.
It weighs 126,5g without battery, and can handle 3S or 4S without trouble.
You can find its frame here : EDGE100X_1306
Description:
Description:
Description:
Second one has DYS 1104 7000kv motors, littlebee_s 20A, gemfan 3025 props, a Piko BLX with an Innova Vtx and a lemonRx sat.
It weighs 81,6g without battery, and can handle 2S or 3S without trouble.
You can find its frame here : EDGE100X_1104
Description:
Description:
Description:
Please feel free to comment
And here is the new version of it, more compact, with a better integration of the camera and access to the FC's USB plug:
Description:
Description:
Nov 19, 2016, 06:03 PM
Nov 20, 2016, 11:39 AM
Team WarpSquad
Phoboss's Avatar
Awesome job, I really like it!
What's the weight of the frame with the pod? (1104 version)
Nov 20, 2016, 05:11 PM
Thanks a lot
The weight of the 1104 frame plus the pod and 4 anodized screws is 20g
Dec 07, 2016, 06:40 AM
EDGE100x Pod new version
Hi all,
just wanted to show the new version of my pod
The first one used a camera mount bought online, which was a little messy as the axis was on the bottom of the camera so if you wanted a high angle it would make the camera deeper in the pod.
In this version, the design is more round, there is an access to the FC USB plug, and the camera mount is part of the pod, with a rotation from 5 to 50 if you fly fast enough
Dec 16, 2016, 12:33 PM
Nice work! that second pod is sweet. Is there a way I could get one? are the shape files posted somewhere?
Would it fit the pikoblx / innoa osd stack? ( http://furiousfpv.com/product_info.php?products_id=76 )
Dec 19, 2016, 05:44 AM
Thank you.
It is designed to fit the Piko/Innova stack. It is not downloadable anywhere yet as i am still modifying it a little bit.
I'll announce it on this thread when it will be released
Feb 14, 2017, 04:00 AM
Up
Nice job.
I'm waiting your pod to buils mine.
Mar 25, 2017, 07:33 PM
New version with foxeer HS1177M
Here is a new version with a HS1177M to have a better image in changing light conditions...
Just 10g heavier than the smaller cam version, 136g
The FC on this one is bluejayF4 mini, running Dshot600 with a 32k gyro and 8k loop.
Flies fantastic
