Mar 03, 2019, 02:02 PM
madgooner99's Avatar
Just ordered one of these babies.
Looking forward to the build
Ray
Mar 04, 2019, 01:20 PM
PaulB's Avatar
If you go through this thread (not too many posts) you will find all that you need to know to get her into the air.
As I have already posted the only problem that I found was getting her to Rise Off the Ground (ROG) in light or zero wind.
Paul
Latest blog entry: Just To Say Hello.......
Mar 07, 2019, 01:44 PM
John 3:16
Hi. How did you set up the radio?
What mixing? Servo direction, etc.
Originally Posted by Jockadopolus
Conditions this morning were good enough to have a go.
Sorry no video of this test
Tried taxi on the grass but the wheels are too small and the model kept nosing over.
So gave it a hand launch, it felt OK but refused to climb and I had to land a short distance breaking the rudder off good job it was only taped on.
Back to the workshop changed the wheels and removed the down thrust spacers and re attached the fin and rudder.
Had one more flight and it was a lot better climbed no problem and will get some video for the next try today.
Joe
Mar 07, 2019, 04:13 PM
Jockadopolus's Avatar
Use elevon mix in your transmitter and set the servos to give the following.
Stick back the head should tilt back
Stick left and right the head should tilt left and right
Hope that helps also this video might help
Joe
R/C Autogyros: Controls and Setup (9 min 23 sec)
Mar 10, 2019, 05:54 PM
John 3:16
Fantastic.
So stick down and the rear of the main prop goes down too?
Joe
https://www.youtube.com/watch?v=YlAuFinUGjM
Mar 12, 2019, 05:12 PM
PaulB's Avatar
Yep...
Mar 31, 2019, 05:29 AM
Looks great
Apr 01, 2019, 02:10 PM
PaulB's Avatar
Enjoy :-))
Paul
May 23, 2019, 11:19 PM
New luobo v2s from banggood test2 (1 min 6 sec)
motor 2212
prop 8*6
esc 30 a
batt. 2200 mA
May 24, 2019, 12:51 AM
britinoz's Avatar
Well done ..looks like you have it well under control.
Happy Landings
Chris...
Aug 22, 2019, 05:05 PM
Joining the Luobo Club!
Hi all!
Ordered, built and flown mine! I love it!
I launch it or ROG if there is some wind.
There is a short video here:
Luobo V2 Autogyro from Banggood (2 min 50 sec)
Thank you all for the useful info I found in this thread.
I have rebuilt the tail with EPP and depron, the original one was very floppy and self-destroyed in the maiden.
One important point is that the photo for setting the pitch in the instructions is incorrect.
The rounded corner must be between the mast and the rotor arm (see attached photo).
This gave me some problems in the first flights (i.e. crashes) as the rotor was pitched too forward.
Other notes:
+ It is very robust, I crashed mine three times before setting the rotor pitch correctly and the Luobo survived the crashes with no problems. I crashed it twice in soft terrain and once in a tree.
- On imperfect landings sometimes the rotor hits the tail and it destroys the left vertical stabilizer.
Wish you happy flying and soft landings,
Raffaele
P.S. I am getting about 5 minutes of flight with a 3s 1300mAh. Which batteries do you use and how much time you get?
Oct 04, 2019, 12:07 AM
John 3:16
cannot fly it
still cannot get this thing to fly.
keeps going off on a right-hand corkscrew into the ground.
Oct 05, 2019, 01:56 PM
PaulB's Avatar
Originally Posted by PaulB
I know that there are some Guys out there who are looking forwards to there first AG flights so tried to ' capture' the whistling sound that you have to get before you can fly an AG.
Rest is a bit boring but at around 3:00 you get a few loop and rolls but as the RunCam 2 Hatcam has no zoom it is not really Hollywood Big Screen. Last few minutes and I messed up the landing but the second one was OK.
https://youtu.be/92kXowY7qpc
Paul
Whistle....
Oct 05, 2019, 02:03 PM
PaulB's Avatar
Can you be a bit more precise, does she go straight and spiral in when you steer??? Does she tip straight over as soon as she lifts off (tried a hand launch)?? Tried a 'hand flight' (as in getting the blades up to speed and then allowing the model to lift fractionally out of you hand) to see if she is trimmed level??
Any chance of a hatcam film, the guys here are the EXPERTS at analysing stuff?????
Paul
