Nov 15, 2016, 08:32 AM
What's going on with my Naze32??
I've been configuring a Naze32 Rev6 with PWM (Devo 7 & RX701). Everything looks ok on cleanflight (3pos mode switch is set up for angle, horizon & rate modes). All channel and switch inputs look good on Cleanflight and calibration has been carried out. The problem is that the Naze has a solid red LED and no green LED at all when in angle or horizon mode, when in rate mode the red LED also extinguishes, and the motors won't arm at any stage.
I've also noticed that I get a solid red and flashing green as expected when the Naze is powered on and transmitter is off, but as soon as the transmitter is switched on the above applies. I'm sure I must be missing something stupid, but I've no idea what it is - any ideas?
Nov 16, 2016, 11:46 AM
RED = AUTO LEVEL
BLUE = POWER ON
GREEN = ARM
What are your min command and min throttle values?
