Build Log
Giant Lego Plane
Latest build, that I'll try to do a proper thread on. Combining two of my favorite hobbies
I found a 10x scale Lego man on e-bay and had to build something for him to sit in. I've always been a fan of classic Lego airport sets, so I picked the set which looked like it had the best chance of flying. 6673-1: Solo Trainer Build will be mostly depron and 1in insulation. Span will be 70 inches. I'll add the studs to the wing incrementally once I get it flying. -A |
Latest blog entry: Stol f-16
Or just make one out of real legos
Very very cool project.
Toby |
For sure, if it flies, it will be in-spite of it's shape
You'll need 80+ of those Lego "dots" to simulate the LEGO look on the wing etc.
A CNC guy could have them for you pretty quick. But He'd need specs ( dia and thickness ) Happy help if desired. Best Bob Hoosier Cutout Service |
-Adam |
It a light night, got the vertical stab done and the other sides of the flying surfaces skinned.
-A |
AJW
The fuselage look very nice and as the original has smooth surfaces the aerodynamics are not that bad but the wings are a bit different, particularly if you made them with scale surfaces top and bottom! I presume in practise you will leave the underside smooth. Following with interest. I can't weight to see how it turns out. |
Thanks. Yeah, going to leave the bottoms of the wings smooth. And fly it without the bumps on top first. If it flies, I'll start adding the bumps, on row at a time. The wing loading should be low enough, that I my need a very efficient wing.
A Quote:
