Nov 09, 2016, 05:24 PM
Dual receiver configuration
Hi,
Does the 9x support two receivers in a redundant configuration ?
Also, is the dual receiver issue with the a9 solved now
/kimi
Nov 10, 2016, 01:36 PM
Team Hitec, Customer Support
Xpress..'s Avatar
You can use 2 Minima or Maxima receivers with the Aurora 9X in parallel. They won't function in series (I.E. receiver 1 is channels 1-6 and receiver 2 is channels 7-12)- you will have 2 receivers that are outputting the same channels on each (I.E. channels 1-6 on both receivers). The best method to achieve dual receiver redundancy is to use 2 Maxima SL receivers with a twin serial input device (I.E. PowerBox SRS or similar).
With the Aurora 9 you can only use Minima receivers in parallel.
You cannot use Optima receivers in parallel due to the telemetry functions.
Latest blog entry: Weekender Warehouse
Nov 10, 2016, 02:55 PM
