Feb 24, 2017, 02:16 AM
foxtechtech's Avatar
Originally Posted by Jay92
Hello foxtech, i have ordered 12 tarot peeper at 7th feb, may i ask when it will be shipped to me?
Hi sir thanks for supporting Foxtech, now in stock only 3 Tarot peepers,and the others will arrive at the end of Feb. we have sent you a email about that.if you need we also can ship 3 peepers to you first
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Mar 09, 2017, 03:45 AM
I want to buy a Peeper drone, but i need more props, can I also order more extra props from you shop?
Apr 16, 2017, 02:53 AM
what's the hight from ground to bottom plate ? I want to check if my gimbal can be mounted on it.
Apr 17, 2017, 04:31 AM
The height from ground to bottom is 13cm, hope it can working with your gimbal~~~
May 03, 2017, 05:11 PM
Folded Dimensions
What are the dimensions when fully folded?
May 19, 2017, 01:06 AM
Tarot power management with Pixhawk
I have a peeper and am putting a pixhawk in it. How do I best use the included Tarot power management system?
May 25, 2017, 12:50 AM
I know the peeper has a flir gimbal +camera. it can be inverted ?
Jun 06, 2017, 04:54 AM
hi, foxtech
Is the tarot peeper 10x camara gimbal inverted mount on my fixwing?
Jun 09, 2017, 09:53 PM
Originally Posted by foreverfly
hi, foxtech
I asked too. They said YES.
Jun 09, 2017, 11:07 PM
hi, foxtech
Yes, It can be inverted.
Aug 22, 2017, 08:23 AM
peeper with A3+LB2+X3
My Setup TAROT PEEPER
Factory set:
Tarot Peeper 750 мм
Martin MT4008 KV 330
ESC - Tarot 40A
Props - 17" - 65
and installed:
DJI A3
DJI Lightdridge 2
DJI Zunmuse X3 (mount busket for M600)
2 x 6S 5000mAh
weight - 1.8 kg, with 2 battery - 3.4 kg
retracks lengthened by 4 cm carbon tubes
The frame is not rigid and can not get rid of strong vibration, can the propellers be replaced?
video result is very bad
Sep 21, 2017, 03:59 PM
Hi, foxtech
Can the tarot peeper 10x camera gimbal be used in position control mode?
Oct 28, 2017, 07:58 PM
Peeper Price hig for just an 'unflexible 'build
For months, the price for a Peeper had put me off.... that and not much detail about 'buildability' or real world performance....
So... price wise.... by far https://www.xt-xinte.com/Tarot-Peepe...S-p140757.html was the cheapest I found and that's where I bought mine. $551.08 was a easier to swallow than any other offering (~$650-$780 from most vendors)
If you subtract out the cost of the include parts.... 2x blade sets at ~$78 4x TL2955 motors (Tarot Martin 4008's) $30 each 4x tarot 40A escs at ~ $24 each
is roughly ~$400. That makes the aluminum arms (which are easily light weight and REAL strong) motor mounts, pivots, legs and chassis worth around $150. Not bad for a 750mm size quad.
My problem(s) though so far.... mounting normal Pixhawk and ancillaries (recvr, osd, 915mhz telem module etc).. first thing that got trashed was the oem electronics. (a joke!... by spec can't even handle the four oem Tarot motors) with no power tap for the Pixhawk.... I gutted the rear electronics completely and removed the innards of the front box and installed the a normal Pixhawk power block and X4 spider of motor power wires into that box (with a few spare power feeds for add ons).
Second issue, oem GPS mount is bad...nothing to keep it from rotating. So I ended up vacuum forming my own canopy that would clear all my goodies inside. Current build is a Pixhawk 2.1 on the chassis with a Here GPS mounted on top the canopy PX2.1, Frsky X8R, telemetry converter, 250mW vid xmtr, minimosd boards are all under the canopy
more coming as my build proceeds
Oct 28, 2017, 08:08 PM
bummer price change...`
oh well ignore that link...looks like sale is over...should have checked it before posting.... it's back at ~650 :-(
ptegler
Oct 28, 2017, 08:12 PM
From the pics
Factory set:
Tarot Peeper 750 мм
ESC - Tarot 40A
Props - 17" - 65
and installed:
DJI A3
DJI Lightdridge 2
2 x 6S 5000mAh
From the pics.. if your props are in that position...I'm surprised it doesn't vibrate itself apart!
Floding props need to be loose enough to self correct, yet tight enough to not freely move.
Initial power up will vibe, then smooth out right away as you start to accell to lift off.
If not smoothed before lift off... DON"T...striaghtne out the blades
ptegler
