New Product
Tarot Peeper Review and Flight Time Test by Foxtech
https://www.foxtechfpv.com/peeper1.html This is a standard long flight time drone. The practical flight time is 47 minutes when loading GO 3-axis gimbal 250g/ transmission module set/10,000mAH lipo battery. Specification : - Diameter: 750mm - Frame Height: 258mm - Main Blade Length: 210mm - Main Blade Diameter: 440mm - Weight: 1565g Your purchase includes: - 1 x FPV Drone Frame - 2 x 17.5" Folding Carbon Fiber Propeller TL2948 - 4 x 4008 Brushless Motor TL2955 - 4 x 40A ESC - 1 x Power Distributor - 1 x Power Manager - 1 x Chinese and English manual Optionals: - ZYX-M Multirotor Flight Control ZYX25 - ZYX-OSD TL300C - GOPRO 3D III Metal 3-Axis Gimbal TL3T01 - FLIR Gimbal Suite (including camera) TL01FLIR - HD Transmitter TL1000 - 5.8G 1000mW Video System TL300N4, 5.8G 300mW Video System TL300N3 - 1.2G 600MW Video System TL300N5 - 22.2V 10000mAh 25C Lipo Battery TL2944 - New D100 Balance Charger TL2942 ================================================= Know about Foxtech from: Official Website: https://www.foxtechfpv.com/ Facebook: https://www.facebook.com/Foxtechhobby-310304665734184/ Youtube:https://www.youtube.com/channel/UCzV...kWFSnYQeYnf0OA RCG: http://www.rcgroups.com/foxtech-hobby-891/ Google+: https://plus.google.com/115734402516823966590 |
assembling Peeper with Pixhawk
It is with ESC s,motors, and props when Peeper is out of factory.
It is with motors, ESCs and props when it is out of factory
Pixhawk is installed in the front of the peeper, the center of gravity is where battery is.
In my case, I didn't adjust Pixhawk settings. |
Assembling pictures for Peeper
Thanks, seems that the Tarot controller is able to ajust it but don't know if Pixhawk can do that, the ideal position is to put the controller in the center of gravity but the battery don't allow it, one option could be to put it in a case under the frame or under the battery.
Post your picture here. Let's see if there is any improvement we can think out.
Latest blog entry: Foxtech Five Oblique Aerial Cameras...
Here it is. Foxtech is offering big Black Friday sales now. The best price NOW. |
its not the centre of gravity the controller needs to be, but as close to the centre of the 4 motors and as close to the horizonal plane as the motors. i think centre of gravity would be in the centre of the 4 motors once everything is mounted (controller and camera at the front). from what i can see, the front arms are shorter than the back. so the centre of gavity would not be were the arms would cross in the middle but back a bit. so this puts the pixhawk way in front of the centre. this for gyros it dont matter because the angle is the same were ever you put it, but accel its a different story. this is a new concept for me having the contoller way out there. there must be thread covering this topic. i have been looking for a enduro setup for small payload. so, so far my intrest has be sparked. peeper? sounds a little creepy i think, well i am a creepy looking guy. |
The ideal position is of course at the centre of gravity. And not only the FC but the GPS as well.
The theory is , when the drone is shaking, the position of the CG is not affected. But if you place the FC and GPS, say on one the end of the arms -for the extreme illustration's sake-, the FC position will be changed vertically and horizontally. If the barometric sensor is so sensitive, it will think that the drone is moving up and down when it shakes/wobble. But of course, it is does not really affect in real life, unless you are a perfectionist. |
