Nov 06, 2016, 02:10 PM
Build Log
Quanum Trifecta
Hi folks
i worke on a smal solution to build out of a trifecta a mini mapping drone.
i use the new Pixracer and the frsky xsr reciver
the motors are babybeast multistar.
tailservo sav÷x sh0263MG
afro opto esc 12A
200mw fpV with cemos camera tvl 600
3S lipo
second camera will be a gopro for easy mapping (not best for this but worable)
but some problems coverd my way i need help with the PID understanding in general
also the working with the new arducopter software is no easy.
Mar 13, 2017, 01:31 PM
Love the modeled top rack! Do you share the files for it?
Mar 19, 2017, 06:58 AM
Awesome build, did you tried autotuning?
Aug 11, 2017, 11:02 PM
Any lucky?
Hi Zaam,
any lucky with PID ? I bought a pixracer too and wish to use with trifecta but I couldn't find any clue about pids.
regards
Oct 09, 2017, 01:40 PM
Hi, anyone has lucky with trifecta + pix racer pid?
I couldn't takeoff - the trifecta spins and crash
Oct 09, 2017, 09:35 PM
Speaking of the Trifecta. frame's on sale at hk for 4.99. I grabbed 2.
Oct 10, 2017, 08:04 PM
HZ Super Cub
Grauwulf's Avatar
I bought a Trifecta quite a while ago in the hopes I could take it with me when I travelled for work because it folded up. I've never really ever gotten it to fly right.
Oct 11, 2017, 08:01 AM
fnffishcore's Avatar
Ditto. Bought one off a user on here. Tail assembly has a lot of slop, arms don't lock that tight. It was cheap enough that I don't feel bad junking it and using the electronics elsewhere.
Oct 11, 2017, 08:59 AM
I have a trifecta setup with SPF3 board and triflight. I documented the build process on my blog here on RCGroup in case you need some help. Main thread link HERE
Oct 11, 2017, 03:57 PM
I'm gonna be using betaflight and the XSRf4O
but I'll be checking out that thread.
I'm aiming for low weight ...although I am gonna be rocking a 1300mah 3s graphene ...which tend to be a bit heavier than similar mah nano-tech batteries.
Wont have the frame though for a number of days since it's on a boat right now.
Oct 11, 2017, 06:22 PM
My trifecta was really flying pretty well with Cleanflight,
but with pixracer I cannot takeoff.
Oct 14, 2017, 03:46 AM
Spent today wiring up my power distribution board and esc's etc. Basically everything to the point of connecting the flight controller.
Seems like my fc's dimensions dont match up to any mounting holes. So i'm gonna have to get creative on mounting it.
Everything else is coming along nicely though. Construction is tight. Tail motor swivels nicely. I wish the thing would mount on some of my better actually 9g metal gear servos but it seems specifically designed for the 9018mg head vs the others i have.
Apr 08, 2018, 01:27 PM
FotoAmg's Avatar
Hi!
i cannot make Triflight .7 beta3 work with Quannum Trifecta and cc3d and cheap MG90S analog metal gear servo
by arming servo twiches fast between all limits
00021 (0 min 25 sec)
When giving 60-80%+ throttle twitching starts to reduce greatly and almost flyable:
00022 Triflight cheap MG90S analog servo twitching (1 min 49 sec)
Apr 11, 2018, 12:32 AM
rcpilot_hun's Avatar
Hi, Guys!
I have 2 similar Trifectas (now one is flyable). I use FLIP32 Naze F1 controller, my firmware is cleanflight 1.13. Its PID value of YAW is most higher than Pitch and Roll values (4-4-8.5!) like Triflight's ones... I use plastic analogue TG9 servo. I noticed, that after takeoff the servo began to alternate with cca 1 Hz freq..... I set PID values of YAW the same as values of Pitch and Roll, and after this attempt the alternating eliminated....
What do You think about this symptom? Why do YAW PID values higher than another one?
Thx: rcph
FotoAMG
Apr 11, 2018, 07:05 AM
FotoAmg's Avatar
Originally Posted by rcpilot_hun
Hi, Guys!
Thx: rcph
FotoAMG
Hey, I need some stable firmware/settings could you drop me your settings? I have CC3d that could be an issue....
what I saw just to answer your question YAW P was way high by default at 0.6 triflight (cleanfligh based FW), in 0.7 which is beta based it is less.
Could you send me your firmware version or better to go to CLI and dump all setting and select and paste all things to a txt file and send/attach here?
For me all triflight 0.7 were do yaw twitching at zero throttle, but tri_yaw_boost setting set to 100 or less it was eliminated but also YAW stabilizatio is eliminated so unflyable
I flashed than triflight 0.6 and now it does not arm even if arm flight mode is active I don't know what to flash next
Discussion Quanum Trifecta for AP? gulzaar Tricopter Drones 10 Mar 24, 2017 05:36 PM
Wanted WANTED Quanum Trifecta Tricopter Frame DevDrive Aircraft - Electric - Multirotor (FS/W) 0 Aug 17, 2016 06:14 PM
Sold Quanum Trifecta Frame gulzaar Aircraft - Electric - Multirotor (FS/W) 3 Aug 16, 2016 11:39 PM
For Sale ARF Quanum Trifecta mish1990 Aircraft - Electric - Multirotor (FS/W) 0 Aug 12, 2016 01:17 AM
For Sale ARF Quanum Trifecta w/ FPV mish1990 Aircraft - Electric - Multirotor (FS/W) 2 Aug 08, 2016 12:11 AM
