Nov 04, 2016, 05:48 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Swallow ... 70mm EDF Jet
Here is my latest little Depron EDF
Weight without battery 485 grams ... built in a day
Just a few little mods to do to the plans but all in all she went together very well ... very quick and easy build
Lockey
Nov 04, 2016, 05:49 AM
Lockey's Avatar
Plans with mods (for EDF or pusher
As usual, all I ask is that ... if you build it, please post pics of your build and if possible a video of your creation in flight
Enjoy
Specs
Wing Span: 1000mm
Length: 840mm
Weight: Without battery 500 grams
AUW with battery: 700 grams
Battery used for maiden 1500 / 3s Graphine (65c)
EDF: Durafly™ Zephyr 1533mm - Replacement EDF Unit w/ Motor https://hobbyking.com/en_us/duraflyt...t-w-motor.html
ESC: Turnigy dlux 55A SBEC Brushless Speed Controller https://hobbyking.com/en_us/turnigy-...a-logging.html
4 x 9 gram servos
A little over one sheet of 6mm Depron
2 x cheap 4mm CF tubes from HK
The whole build was glued together with hot glue
Lockey
I was so excited I forgot to turn on the video cam until about 2 mins into the flight when I remembered ... so I landed and as I only had the one battery with me, I only managed a very short flight on video
Plans are now available at: http://www.lockeysrcplans.com
Swallow Maiden (1 min 29 sec)
Nov 04, 2016, 06:42 AM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Very very quick on this one mate! Well done she looks Awsome mate this should float around beautifully . Can't wait to see her fly
Lol... check your heading.... there's more than a 7mm fan in this one
Nov 04, 2016, 06:54 AM
I Look, Listen, and Learn
Timbo383's Avatar
Very cool looking Lockey.
I know you're drooling over that v tail Duke.
Nov 04, 2016, 07:22 AM
Lockey's Avatar
Thanks Duke ... changed to 70 mm Fan
Yes Timbo .. I can see Duke drooling over the V tail .. AGAIN
Just as well its quite light ... that wing is very small, just hope there is some lift from the fuselage
Lockey
Nov 04, 2016, 07:46 AM
Timbo383's Avatar
Always like your designs Lockey, haven't seen one yet that I didn't want to build. I just don't have the time or patience to build them like you do. I still do the simple and easy ones. Maybe when I finally get to retire I can go back and do some of them.
Nov 04, 2016, 08:02 AM
Lockey's Avatar
Thanks Timbo, lots of time to do building when you retire mate
Lockey
Nov 04, 2016, 08:49 AM
Looks very nice! What is the overall wingspan? Do you think this could be done as a pusher? I think it may lose some of the cool thrust tube curve if I try to use an FT style pod.
Nov 04, 2016, 09:00 AM
When cows fly!
Lockey! Love this little plane! Totally cool Keep Duke away from that V-Tail, his drool will warp the wings! Can't wait for the maiden
Nov 04, 2016, 09:09 AM
Lockey's Avatar
I will do a mod for a pusher if you want jpot1
Wing span is just a metre with the wing tips ... its loosely based on the PAK-TA Concept Jet
Lockey
Nov 04, 2016, 09:22 AM
Wing span is just a metre with the wing tips ... it loosely based on the PAK-TA Concept Jet
Lockey
Lockey, that would be great. This reminds me a bit of the sky ray due to curved fuse but I like the looks of this more. Due to my electronics I may need to shrink this down by 15% like I did with the sky ray. Looking forward to plans when ready.
Jason
Nov 04, 2016, 09:31 AM
Lockey's Avatar
It could be modified to a pusher and still keep the Fan tube
Lockey
Nov 04, 2016, 09:52 AM
Lockey
Wow, that was fast! I'll tweak a bit just like I did on the sky ray to fit the more "square" FT pod that I use on my planes.
Description:
Nov 04, 2016, 10:32 AM
Lockey's Avatar
Plans posted on post #2 ... enjoy
Lockey
Nov 04, 2016, 01:42 PM
skumgummi dave
Beautiful build and plans Lockey. Thank you sir.
Dave-
