AOSENMA CG035 Brushless Double GPS 5.8G FPV With 1080P HD Gimbal Camera Follow Me Mod - Page 121 - RC Groups
Nov 06, 2017, 04:12 PM
The Denying Dutchman
Denying Dutchman's Avatar
Originally Posted by Noviardi
i'm still doubted about this drone..
buy another full set drone or repair it by replace all esc and 4 motor..
it has flip over take off every time i tried..
and the banking issue when rc input applied
Why not buying better ESCs and motors? A 3s CG035 is a whole lot more fun than replacing parts and keep throwing money at it without any progress.
Nov 06, 2017, 07:07 PM
what do you mean for 3s cg035 is it "latest black one with optical flow"?
Nov 07, 2017, 12:00 AM
banggood has 20 discount from 205 for black version..
Nov 07, 2017, 04:55 AM
No convert the Aosenma to run on 3s batteries. instead of buying the standard 2s ESCs and motors.
Nov 07, 2017, 04:57 AM
I hear a lot of talking about the black CG035, but I don't see any good results. I wouldn't buy it!
Nov 07, 2017, 07:14 AM
The CG035 runs just fine on 2S... It's not really intended to "punch"...
If you want to fly like that, there are much cheaper racing quads for less than $120 that come up from time to time RTF. Most are 3S, even 4S - You can run them in angle mode too if you like, but they are a real buzz to fly.
They are far more durable and will withstand a few crashes, but don't make such nice camera platforms.
David.
Nov 07, 2017, 12:40 PM
just convert the esc? how about the fc? will it toast the mcu? interesting
any one succeed converted?
Nov 07, 2017, 06:34 PM
The CG035 is equipped with voltage regulators, the question is what the max. voltage is they can handle. Assumably a lot more than 8.4v.
As for "the CG035" isn't designed to punch"... why not? Sure, the plastic cover doesn't like crashes and neither does the electronics, but a carbon frame isn't very expensive. The carbon frame I bought is large enough to hold 2 stock batteries! (without plastic cases of course.)
Nov 14, 2017, 07:19 AM
So everyone finally gave up on this quadcopter? Probably for the best. RIP CG035!
Nov 14, 2017, 07:35 AM
biomecanoid's Avatar
Why you say that ?
Nov 14, 2017, 07:40 AM
Originally Posted by biomecanoid
Why you say that ?
No post in 6 days more or less means that people have moved on to other quadcopters.
Nov 14, 2017, 07:45 AM
sadko2000's Avatar
No posts means no new problems
Nov 14, 2017, 07:52 AM
lol
Nov 14, 2017, 05:25 PM
Torstie's Avatar
No, we never give up.
Maybe flying season is over (at least strongly reduced) here at northern hemisphere?
Nov 15, 2017, 06:03 AM
CJ7hawk designed lightweight gimbal/brush servo/F3 flight controller -- (17)
Further to Post #1787, trying to find the best matching of rubber damper, gimbal flight controller PID for roll & pitch and servo voltage.
Current rubber damper & servo voltage are attached photos.
A. FireFly Q6 Gyro OFF, F/C PID 100/90/80
Nov 15 Q6 OFF 3 41v 100 90 80 (2 min 51 sec)
B. FireFly Q6 Gyro OFF, F/C PID 100/20/20
Nov 15 Q6 OFF 3 41v 100 20 20 (1 min 58 sec)
C. FireFly Q6 Gyro ON, F/C PID 100/20/20
Nov 15 Q6 ON 3 41v 100 20 20 (2 min 36 sec)
Camera Gyro OFF (Stabilization off) shows vibration and Gyro ON reduces the vibration but too much wavy movement at 4 corners.
Need further try to find best matching position.
In the meantime, it is 642 flights today after replacing 3 ESCs in Early April.
At that time 4 motors did not rotate properly so changed 3 ESCs (no change on motors).
Since then no problem. Actually I changed one ESC in Early July (itís 338 flights after the replacement of 2nd ESC).
CG035 has problems but once fixed, it is very reliable so far.
I never use auto take off after flip back accident which was caused by faulty ESC which can not rotate 4 motors properly.
So, I use manual take off. Some time I found one or two motors did not rotate when unlocked.
Then locked and unlock again until 4 motors rotate properly.
Now I can take off.
With this procedure, no take off accident.
Aiolosimport
Alert AOSENMA CG035 Brushless Double GPS 5.8G FPV With 1080P HD Gimbal Camera Follow Me Mod siriusflier Mini Multirotor Drones 3 Oct 29, 2016 11:04 AM
