C1 Chaser 1200mm Wingspan EPO Flying Wing FPV Aircraft RC Airplane KIT - $65 - RC Groups
Nov 03, 2016, 09:29 AM
New Product
more details: http://www.banggood.com/C1-Chaser-1200mm-Wingspan-EPO-Flying-Wing-FPV-Aircraft-RC-Airplane-KIT-p-1102080.html
flight video:
New model C-1 chaser1200mm flying wing EPO foam RC airplane KIT w/HD camera Big wing wing Z84 (4 min 50 sec)
Description:
Item Name: C1 Chaser
Wingspan: 1200mm
CG: 103-108mm from the leading edge at the wing root
Material: EPO
Flying Weight: 660g (1000g with FPV equipments)
Features:
Simple layout, easy to install, easy to use
Can do slow or fast fly,switching freely
Big cabin space, can also be used as FPV aircraft.
Equipped with a damping platform mounting hole on the engine room cover
Machine belly installed two anti-wear plastic, in front of a piece can play the role of anti-wear, it can also be used as the ejection hook.
Maximum recommended propeller size is 8 inches
Nov 03, 2016, 02:59 PM
What is max propeller size?
Nov 04, 2016, 02:12 AM
Sent by Touch Typing
On the Bangood site 8x6 (for FPV)
Nov 04, 2016, 08:13 AM
Ordered one today, but on back order already. Only saw it appear on site yesterday. Expected back in stock middle of this month.
Nov 04, 2016, 05:14 PM
Rag The Nuts Off :)
Yea sorry about that, we cleared the bg warehouse out of them yesterday
Matt
Nov 05, 2016, 05:43 AM
Matt
BG site shows mine despatched. Either they found some more, new stock arrived, or they nicked one out of your order for me.
I will be setting mine up with Turnigy 2826 2200kva, 7 x 6 prop, Turnigy 90S metal geared servos and a 30 amp esc. Not using for FPV, just fly around and thermal it.
Nov 12, 2016, 03:34 PM
smoothvirus's Avatar
UNBOXING the C1 Chaser Flying Wing [ Full Version ] (28 min 35 sec)
Nov 12, 2016, 04:57 PM
I pulled the trigger on the kit. Don't know if I'll build it out this year but will try for the 2017 season. I'm going to use the same power setup as what is in my Mini Talon and the same batteries. Commonality of the batteries with the MT is what convinced me to get one.
If you order one from banggood you can use the coupon code rctech1111 to get 8% off.
Nov 14, 2016, 12:02 AM
Received my C1 Chaser from BG today. Looks good.
Nov 14, 2016, 11:36 AM
TBS Crossfire or DragonLink?
SmoothV
Gonna be interesting to see how well
the miniTalon power setup coincides with
this new C1
(SS2216 1250kV, 4s Lipo, APCe8x6, ESC 40amp)
Nov 14, 2016, 04:13 PM
C1 Chaser MAIDEN Flight + Pre-Maiden Commentary (12 min 12 sec)
Nov 14, 2016, 09:14 PM
Family, Work, FPV!
Realms's Avatar
Originally Posted by LexusFPV
SmoothV
this new C1
Yeah, I'm super keen on this setup. Imagine the range you'd get with a large Li-Ion pack!
Nov 15, 2016, 03:40 AM
Rag The Nuts Off :)
Howdy Rob,
I made a review on the model this morning here https://www.rcgroups.com/forums/show....php?t=2778388 which will help you.
If you're going to be flying her line of sight, I soon got bored of the standard elevon movement.
So I'd suggest looking at giving them more travel, either through moving the push rods and/or the servo movement in the transmitter.
Also look out for the "big dip" she'll do when launching, you can see that in the maiden video.
Hope that helps Rob, she's stunning to fly.
Matt
