Oct 29, 2016, 03:56 PM
Car Bashing
Jym73's Avatar
Mini-Review
WLtoys 10428 - Wild Warrior Truck 1/10 - Rock Crawler - Review
I received this WLtoys 10428 from banggood to do a review.
Photos :
Name: WLtoys 10428 - overall .jpg
Description: Name: WLtoys 10428 - side .jpg
Description: Name: WLtoys 10428 - front .jpg
Description:
Name: WLtoys 10428 - rear .jpg
Description: Name: WLtoys 10428 - bottom .jpg
Description: Name: WLtoys 10428 - a-arm detail .jpg
Description:
Name: WLtoys 10428 - cockpit detail .jpg
Description: Name: WLtoys 10428 - battery tray .jpg
Description:
Little story :
This WLotys 10428 is the big brother of the Wltoys 12428. Excepted that they look same it is the only comparison we can do. 10428 is bigger with lot of more spec. WLtoys 10428 is same as WLtoys K949 and A333. It is also a copy of the Vaterra twin hammer. When some people say that Wltoys 12428 is a twin hammer i answer no, the 10428 is a twin hammer.
Unboxing :
• WLtoys - Wild Warrior Truck - 10428 - Unboxing • (14 min 16 sec)
Specifications :
Scale : 1/10
Lenght : 445mm
Width : 245mm
Wheelbase : 287mm
ESC : 50A waterproof.
Motor : 2 in 1 esc/receiver.
Battery : 2s 25c.
Transmitter : 3 channels, 6 x LR6/AA batteries (not included)
Size comparison :
Name: WLtoys 10428 - size comparison .jpg
Description:
From left to right : Wltoys 10428, WLtoys 12428, BZ 444 1/10
Parts inspection :
Wheels :
Name: WLtoys 10428 - wheel .jpg
Description:
- 110 x 38.5mm
- Bedlock with foam.
- 12mm plastic hex hub.
- pin : 1.5 x 9.5mm
transmission :
I show details of the center gearbox and gearings in my unboxing video : https://youtu.be/6g2hiIroKK4?t=10m19s
Front differential :
Name: WLtoys 10428 - front differential .jpg
Description: Name: WLtoys 10428 - front differential 1 .jpg
Description:
- flanged ball bearing.
- 4 spiders.
- There is diff. oil but not a lot.
- Steel used seems pretty good.
Gearbox and bevel gear :
Name: WLtoys 10428 - front gearbox cover .jpg
Description:
- Front gearbox is held by 4 screws.
Name: WLtoys 10428 - front bevel gear .jpg
Description:
Rear differential and solid axle :
Name: WLtoys 10428 - rear differential 1 .jpg
Description: Name: WLtoys 10428 - rear differential 2 .jpg
Description: Name: WLtoys 10428 - rear differential 3 .jpg
Description:
- Almost same as front (spur gear and diff. housing) but it is locked with a cross metal part.
Name: WLtoys 10428 - rear differential cover .jpg
Description:
- Rear axle has a diff. cover to add some grease eventually.
Name: WLtoys 10428 - rear gearbox axle  .jpg
Description:
- Rear axle is composed of 5 parts.
- Rear axles seem strong.
Bevel gear :
Name: WLtoys 10428 - rear bevel gear .jpg
Description:
Front CVD :
Name: WLtoys 10428 - front CVD .jpg
Description:
- 3.9mm axe diameter ( at the most high diameter)
Suspension :
Front a-arm :
Name: WLtoys 10428 - front suspension .jpg
Description: Name: WLtoys 10428 - front a-arm .jpg
Description:
- Adjustable tie rods.
- Hub carrier is held by two axles blocked with grub screws.
- Hing pin : 42.8 x 3 mm
Electronic :
See details in my unboxing video.
First thought :
- Wltoys must take care of the building of their car, a missing ball bearing in gearings housing can do lot of damage on gearing.
- Other than that car is well built.
- Pretty good material on transmission.
- Rear center cvd,on the gearings housing side, isn't well centered, its inside diameter is bigger than the gearbox axle's diameter.
- Good radio with many parameters.
- 2 speeds in gearing housing is a nice thing for a crawler.
- Shocks need some settings.
- I added oil in diff. and grease on spur gear diff.
- 8 screws to open the body shell (10 to totally remove it ), can be annoying to access the chassis.
- Big compared to an 1/10 buggy.
- As for WLtoys 12428 i like its funny color.
Videos :
Speed test :
• WLtoys - Wild Warrior Truck - 10428 - Speet test • (20 min 24 sec)
- Going at fast speed isn't so important for crawling, but it is still interesting to know.
- About off-road sequence, i must set reverse power.
- Works pretty nice and has good crawling capacity.
Feel free to ask any questions
More to come , stay tuned
Oct 31, 2016, 02:43 PM
I meant to do that
eMoon's Avatar
It's the same thing as the K949 (aka Twin Hammers Clone) that's still available here:
http://www.tinydeal.com/wltoys-k949-...-p-151798.html
Looks like new colored plastic and led lights are the only changes made.
Oct 31, 2016, 02:47 PM
Car Bashing
Jym73's Avatar
Yes, it is same as WLtoys K949, A333 and Twin hammer.
Oct 31, 2016, 02:56 PM
Is it exactly the same or subtle differences like between the FY03 and 12428?
Oct 31, 2016, 03:01 PM
Car Bashing
Jym73's Avatar
12428 and Feiyue are 1/12, this one is 1/10 and bigger than a 1/10 buggy. Its transmission has 2 speeds. We can say that 10428 is the big brother of the 12428.
Otherwise it is compatible with twin hammer parts. K949, A333 and 10428 are differents kind of finition, color.
10428 doesn't have led light.
Oct 31, 2016, 09:57 PM
I meant to do that
eMoon's Avatar
Oh, the title of the ad page says it does, but I didn't look any deeper than that.
In any event theses are great trucks. I have two of the k949s. Well built and every after market part swaps in well minus a bearing size here and there.
Sent from my SM-G900V using Tapatalk
Nov 01, 2016, 02:50 AM
What I mean is if you compare the 12428 and FY03 there are slight differences like slipper clutch motor size etc
Are there also differences between the larger 1/10 versions or are they more or less the same?
Nov 01, 2016, 04:56 AM
Car Bashing
Jym73's Avatar
What i mean with this sentence is that they are identicals, just an aesthetic difference . I don't own a twin hammer but twin hammer must have better material quality i think, not the same price also.
Nov 01, 2016, 10:45 AM
Low budget fun
Beaver_XT's Avatar
How's the transmitter? I had the other Tx from WL and it has big deadzone in the middle. I have to twist the wheel from centre a lot to get the steering registered. Which makes it almost impossible to drive with precision.
Nov 01, 2016, 10:54 AM
Car Bashing
Jym73's Avatar
i didn't tested it yet, i will able to say that later.
Nov 06, 2016, 05:08 AM
Car Bashing
Jym73's Avatar
Review started
I started my review, see first post.
I don't have this problem on mine.
Nov 06, 2016, 02:09 PM
The front diff is not going on the 12428 WLtoys?
it would be interesting as it is metal !
Nov 06, 2016, 02:39 PM
Car Bashing
Jym73's Avatar
No, really too big.
Nov 06, 2016, 03:41 PM
Low budget fun
Beaver_XT's Avatar
Thanks. Now I want the car even more than before.
Dec 12, 2016, 02:34 AM
Hello, is this model waterproof? I don't see any "waterproof" logo printed on the box. TQ
