Hitec X1 Nano AC Balance Charger
Hitec's X1 Nano is a small balance charger that operates on 100-240V AC for charging small to medium sized lipo batteries at home...
Simple Charger for Home Use
Hitec's X1 Nano is a small balance charger that operates on 100-240V AC for charging small to medium sized batteries at home. It can handle 6-8 cell NiMH and 2-4 cell Lipo, LiFe and even High Voltage (LiHV) lipo batteries. The charge circuit provides up to 50 watts of power at up to a 4A charge rate. Using the charger is as simple as selecting the battery type and setting the charge current switch to your desired rate. There are LED status indicators showing the charge status so you know how things are going.
Check out the X1 Nano AC Balance Charger at Hitec.
Charging Specifications:
  • Power Input: 100 - 240 volts AC
  • Battery Type / Cell Count: LiPo, LiFe and LiHV: 2 - 4 cell / NiMH: 6 - 8 cell
  • Charge Circuit Power: 50 Watts
  • Selectable Charge Currents: 1, 2, 3 or 4 Amps
  • Current Drain for LiPo Balancing: 300 mA per cell
  • Cell Termination Voltage
  • LiPo: 4.2V / LiFe: 3.6V and LiHV: 4.35V (0.02V)
  • NiMH: Delta Peak Voltage
  • Weight: 6.6 oz (188g)
  • Dimensions: 2.7 x 4.3 x 1.6 in (69.4 x 110.7 x 40.5mm)
