First Look - The Skywalker EVE-2000 - RCGroups Review - RC Groups
We've got the big and (arguably) beautiful EVE-2000, available from Banggood! Join us as editor Matt Gunn takes a close look at this foam behemoth.
Unboxing the Skywalker EVE 2000 Review
Unboxing the EVE Before the Review
I recently reported on the announcement of the newest foam FPV aircraft to wear the coveted Skywalker name: the EVE-2000. It's a big foam twin airplane with enough room inside for just about any sized LiPo(s) and on-board electronics that you can stuff in there. The EVE-2000 can serve multiple purposes; it's equally at home flying FPV missions for fun, or hauling a downward-facing camera for mapping.
Banggood supplied me with the Skywalker EVE-2000, and after doing my homework, I'm confident that they have the best deal on this plane at the moment: the price is currently set at $239 for the electronics-included package, and that's with free shipping. Let's take a closer look at the EVE-2000, before I get rolling on the full review.
CLICK HERE for the Skywalker EVE-2000 from Banggood.
Parts List:
Review Video
Unboxing the Skywalker EVE 2000 - RCGroups Review (14 min 59 sec)
Photos:
Stay tuned for the full review of the Skywalker EVE-2000, with the Eagle Tree Vector at the flight controls.
Oct 30, 2016, 09:13 PM
KI7CBF
xtrmtrk's Avatar
Looks promising!
The instruction sheet linked from the Banggood site says it has parachute landing. Are any of the parts for that included?
Oct 30, 2016, 09:28 PM
RCGroups Editor
Matt Gunn's Avatar
Originally Posted by xtrmtrk
Looks promising!
Nope. Nothing parachute related is included. Maybe that bottom plate could be an anchor point? Not sure though.
Oct 31, 2016, 10:15 AM
typicalaimster's Avatar
You can also look into the Skywalker landing gear. It's on FPVModel and a few other places that sell the Skywalker. That will turn the Eve into a tail dragger. You may have to beef up the bottom plate a little. Similar to what's done on the Anaconda.
Oct 31, 2016, 12:21 PM
RCGroups Editor
Matt Gunn's Avatar
wow. that looks really clean!
Oct 31, 2016, 04:56 PM
Gravity is a cruel mistress...
Blucross's Avatar
Looks good, great review as always! One correction though, banggood.com shows that the PNP version (electronics included) is $319.99 and the $239.99 version is airframe only.
Nov 02, 2016, 03:22 AM
Looks great! Why would they use 3 bladed on a long endurance plane? With no landing gear clearance can't be a problem. Don't they want the max efficiency?
Nov 02, 2016, 10:21 AM
RCGroups Editor
Matt Gunn's Avatar
Good point. Utilizing a 2 blade might be the way to go, for efficiency and ease of propeller balancing.
Nov 02, 2016, 10:52 AM
I tried to find the distance between the motor mount and fuse. I wonder if an 11 or 12 inch two bladed would fit. It sure looks like this would give a Mytwindream a run for its money. I've got a 1200 acre mapping mission in my future. I could run this with a Pixhawk 2.
Nov 02, 2016, 01:32 PM
You have 180mm from the center of the motor to the root of the wing where it joins the fuse. So we're talking ~7 inches on one side. Probably a max of a 14" prop if you wanted to go crazy. At 7-3/8" you WILL hit the fuse.
Nov 02, 2016, 01:56 PM
Thank you for that. Very nice! Yeah... 14" would be pretty huge on a 28XX motor. I'm looking at the 650kv 2825 Motrolfly on 6S swinging an 11x7 if it's not too heavy. It is bigger than the suggested 2815 but I'd like to swing a big prop on 6S. That would let me use my multirotor batteries in it with good eficiency.
Nov 02, 2016, 08:48 PM
I'd venture to say at even 4s you could probably use a Multistar 10,000mah pack with the 'PnP' bundle. Seeing the packs have a 200amp capacity for 10 seconds. That's long enough to take off and get to a parking altitude.
The ESC's provided are 40a. So at most you'd be pulling 80 amps before you fried something. The motors they provide are also 2816/10 650kv. What sucks is you can't find any specs on a 2816/10 motor out there. Seems like they did a custom motor for this plane. They also provide you with 10x6 3 blade props. Usually the 3 blade rule is Prop Down, Pitch UP. I'm also curious what an 11x7, 11x6, 11x5 combo would do on this with the factory motors. For now I plan on testing with stock stuff until I can get telemetry data in hand.
I think the only thing limiting motor size is the motor mount itself. You just have to make sure it fits on their standoffs.
Nov 02, 2016, 09:18 PM
Thanks again for that. Good info.
If running a Pixhawk setup (that I have a lot of experience with), part of the telemetry that can be sent back through both the telemetry radio and the minimOSD is amp draw, so that could be monitored.
What do you think of the stock servos on their PnP plane?
Nov 03, 2016, 01:28 AM
Gaftopher
Gary Mortimer's Avatar
How does it fly Matt?? Friend has one here, we will be putting an APM in it. I have not actually seen it yet!
Nov 03, 2016, 08:30 AM
RCGroups Editor
Matt Gunn's Avatar
Still building her out. Should be ready for the maiden next week. I'm optimistic!
