This thread is privately moderated by myrcmodel, who may elect to delete unwanted replies.
Oct 24, 2016, 09:48 PM
myrcmodel's Avatar
Hobbywing XRotor Micro BLHeli-S Multishot 30A 2-4S ESC
Hobbywing XRotor Micro BLHeli-S 30A ESC is the latest BLHeli-S ESC released by hobbywing.This ESC is specially designed for competition FPV drones.Compared with the Xrotor BLHeli 30A, the BLHeli-s 30A is lighter, and it supports the DEO technology. Meanwhile, it supports oneshot125 mode, oneshot42 mode and multishot mode.
Main Features:
Super Small and Light
With the remarkably small size (23.8x14.5x5.8mm) and light weight (6g),XRotor Micro 30A BLHeli-S is an ESC specially designed for competition FPV drones.
Quality Components
The use of EMF8BB21F16G MCU (with the operating frequency of up to 48MHz),3-in-1 drive IC, American Fairchild MOSFETs, imported quality ceramic
capacitors, 3-ounce copper and 4 layers of PCBs guarantees less heat, higher efficiency and rapider response.
BLHeli-S Firmware Ready
The ESC supports the original BLHeli_S firmware. Users can flash or upgrade the firmware via the signal cable (on ESC) and program 4 ESCs simultaneously after connecting their flight controller to the BLHeliSuite software (if the flight controller uses the CleanFlight or betaflight firmware).
Hardware Generated PWM and Damped Light Mode
The ESC firmware uses hardware generated motor pwm for smooth throttle response and silent operation. Damped light does regenerative braking, causing very fast motor retardation, and it inherently also does active freewheeling.
Regular/Oneshot125/Oneshot42/Multishot Modes Supported
The ESC also supports Oneshot125(125-250¦Ěs)high-speed throttle signals, Oneshot42(41.4-83.3¦Ěs)and Multishot(5-25¦Ěs) super high speed throttle signals besides regular PWM(1000-2000¦Ěs)throttle signals.
Twisted-Pair Signal Cable Reduces Interference
The twisted-pair throttle signal cable effectively reduces interference produced in signal transmission and makes the flight much more stable and reliable.
Specifications:
Product Name: XRotor Micro BLHeli-S 30A
Cont./Peak Current: 30A/40A
LiPo Cells: 2-4S LiPo
BEC Output: No
Input Wires: Red-18AWG-100mm*1;
Black-18AWG-100mm*1
Output Wires: No wires but solder tabs
Input Connectors: No
Output Connectors: No
Firmware: BLHeli-S A-H-50 16.3
ESC Programming: Stick Programming,BLHeliSuite
Throttle Range Calibration: Supported
Stick Programming: Supported
DEO: Supported
OneShot42 Mode: Supported
OneShot125 Mode: Supported
Multishot Mode: Supported
Timing: Supported
Motor Rotation: Supported
Weight: 6g
