Jun 06, 2019, 01:12 AM
erno's Avatar
Originally Posted by Vapor Trails
I've never flown a single motor so long that it need bearings replaced... and I got some old motors!
This is pity, but mine 30CC v2 flown only two flights and:
2 июня 2019 г. (1 min 3 sec)
2 июня 2019 г. (0 min 40 sec)
2 июня 2019 г. (0 min 29 sec)
Originally Posted by erno
... Does anyone know are of the dimensions of the bearings in v1 and v2 the same?
Yes, they are the same )))
Jun 06, 2019, 02:32 AM
"BIG" Vyper Addicted
Chris SW's Avatar
https://youtu.be/tEoS174UG2s
https://youtu.be/BVl6EKW5Jds
https://youtu.be/XAJAAUqIjdw
That is a shame. I did wonder whether you had checked the tightness of the bolt holding the inner commutator and the outer case together? When I look at the picture I can se some wear around the threaded hole in the main shaft.
Jun 06, 2019, 05:03 AM
erno's Avatar
The bolt was good tighten. There are remnants of the thread lock glue on the photo.
Or maybe it is leaked grease from the bearing... But anyway the bolt was tightened.
Jun 14, 2019, 04:42 AM
Hi All, I just received my XPWR 40 and the CC EDGE 120HV ESC. Do you guys know what are ESC settings that work best with the XPWR 40?
Jun 18, 2019, 07:05 AM
We have several broken XPWR30 in our club. The ring that hold the magnets will get loose on all of them. Mine did hold up well. I still have a new one lying around. I would easily recommend the XPWR60 (too bad it doesnt exist with 160KV for 14S) or all the other XPWRs, but not the XPWR30.
Jun 18, 2019, 02:42 PM
winter1's Avatar
Originally Posted by Leelander
.....The ring that hold the magnets will get loose on all of them..........
I had the same problem. ***winter***
Jun 19, 2019, 12:21 AM
FloBau's Avatar
Was this issue solved on the XPWR 30CC V2?
Jun 19, 2019, 09:55 AM
winter1's Avatar
...it is an XPWR 30CC "V1" engine...... ***winter***
