XDP problem on Windows7 - RC Groups
Oct 23, 2016, 08:59 PM
Smyk's Avatar
Hi All
I have had installed all XDP programs while back on my Windows7 computer and have use them last winter season to check settings with no problem.
Now I have been trying to use it for several days , but it says it does not see device or shows the run time error
it is possible the issue is covered somewhere in the forum, but I can not find it.
any clue?
PS. I got problem to install and run XDP software on W10, but it is worth to join the other thread showing the same issues
Oct 24, 2016, 01:36 AM
You need to install the software in Adminstrator mode, and then run the XDP program in Adminstrator mode.
Oct 24, 2016, 08:19 AM
Smyk's Avatar
Getting there
Thanks Jim
Actually I was binding receivers wrongly
let me master all that and I will get back to it in Windows 10 again
mike
Oct 24, 2016, 09:22 PM
Smyk's Avatar
almost there
I have managed to run XDP programs on both W7 and W10
*There is two Types of binding among these programs to be aware of to make it right.
*Analyzer and RSSI test working good
*I got the problem with RxDiag and Tx Diag. It will bind to to Rx/Tx , but will not progress "connect to" Rx/Tx .... any clue?
* there is 3 Hop Modes - please refresh my memory - I am sure there is a big write up about it in this forum
! Predictive - the orginal XPS mode -- is nessesary to run telemetry and some other settings. it is a default mode on XDP.
! Full Time hopping - the way Tx modules and Tx come from Jim and used mostly. best for noisy environment.
! Adaptive .... well.... I miss this one - what is used for?
I know how to set hopping mode on Tx, but how you doing it on Rx?
I have been using XPS stuff from around 2006-2007 exclusively , but very seasonal. I reed probably every post in this forum and thought I know everything about it. Wait until you really dig in and start to use this technology at full. Questions pupping up. I use A123 cells since 2006. Awesome source of energy. After 10 years they still good and hold the charge for years.
My Txs are all MPX and I love them because I understand them
Ehh . I am 60 and I do fly big scale gliders and tow planes. I can not afford mistakes. I am unfolding the 2017 season right now
Thanks for any input
Oct 24, 2016, 11:58 PM
There is no need to do anything with the RxDiag You can just bind the receiver and test it. The TxDiag requires that you put the transmitter module into hopping mode 1.
Thanks your support for the last decade!
Nov 14, 2016, 10:16 AM
Smyk's Avatar
but not there yet
Saga is not over yet
Thanks for a suggestion Jim
I have spent big chunk of time on several subjects over XPS product line and will try to expose my frustration in separate postings
here is first one
Running RxDiag
I am using this post as a guide to all XDP programming ( including PDF there)
https://www.rcgroups.com/forums/showthread.php?t=863786
I am able to Bind and Connect to the original 8 and 10 Channel receivers, but I can not bind to any Nano or RFU Rx. Mentioned post doesn't cover RFU binding and connection procedure, but i think it is the same like Nano's. Every time I try to bind Nano or RFU it shows Error 76 ( picture above in first post)
Any suggestion?
What is a current procedure of binding Nano and RFU to RxDiag?
I know to deal with all XDP programing there is two types of binding to consider.
Nov 14, 2016, 08:02 PM
Update your software! You are using v1.6 of the RxDiag. The latest is v1.7, which supports the Nanos and RFU. Sorry I missed that - but v1.7 was released years ago and I just figured you had the latest software.
You can download the v1.7 here, and then copy it to your C:/Program Files(x86)/XPS/ folder.
Note... there appears to be an issue with our server. I can FTP into the server and see the correct versions, but pulling the files (via a download) downloads an older version. Very odd. So, the file linked to above is located on a different part of the server and is the correct version.
Nov 14, 2016, 09:54 PM
Smyk's Avatar
Woops
That is kind of embarrassing
Thanks for heads up.
Actually it was 1.5 version and seems like just yesterday.
Automatic update went to version 1.6
I have to go trough entire spectrum of these updates to get to the more familiar territory.
