I received the new module that I ordered from Amazon in the mail early this morning and it works great. My H36 is about a hundred times easier to control and flies very smooth and responds excellently to the stick inputs on my Taranis. A real pleasure to fly this little guy now. The only thing I need to figure out now is how to program the "flip" feature into the Taranis. Anyone know how it's done? Any help would be appreciated.
Cheers Steve |
Flip should be on channel 6. You toggle that channel then move the right stick to do a flip.
I tried to rig up to reprogram mine to TAER channel order so it would work on my JR radio but so far no luck. I was hoping it had the Arduino boot loader on it but it must not. It is programmed for AETR which won't work for me.
Thanks. I have "flip" set up on ch 6 on the inputs page and assigned to the spring loaded toggle switch "SG" but when I pull and release the switch and input a direction on the pitch / roll stick it doesn't flip, it just banks in that direction. What am I doing wrong? Cheers Steve |
Do you have your channel 6 set up properly? Check that you are getting full range on ch 6 with your switch. IT should do flips. My goebish module does flips when I toggle ch 6.
Cheers Steve |
I do not have a Taranis. I fly a JR radio with Goebish module. (same FW as in this module) I have channel 6 set up on my flap swicth. 100% throw on it. I just toggle that switch and then it flips when I give it aileron or elevator input.
Ahh, I see. Ok well thanks very much for your input. I will keep working with it and see if I can figure it out. BTW, I flew JR for many years before I got my Taranis. I still have 2 of the original PCM 10's from the early 90's and an XP 8103 I use for my RC boats. All are still excellent Tx's. Cheers Steve |
I fly all of my little quads with my old JR 388. I also have a 9303. I have many old JR radios and they all have the plug in TX module so I can modify them easily to do all of the new protocols.
I was able today to successfully load new FW on this board to run with my JR radio with TAER channel order! I had to first program the Audrino boot loader onto the board - then I could load new FW with the channel order switched. It now flies my E010 just fine!
Cheers Steve P.S. I could not get the 1st module I bought from Banggood to bind either. I ended up buying a 2nd one from Amazon and it seems to work fine. |
I am happy to say that I finally got the "Flip" working on my jjrc H-36 and the still and video cameras working on my Syma quads. But for some unknown reason I still can not get the Symas to "flip" lol. I have flip set up on the Symas on channel 6, same as the H-36 as the instructions say but they just won't do it. I'll stay with it though and hopefully get it figured out. My dear sweet wife (God rest her soul) always said I was stubborn and didn't know when to give up.
Cheers Steve |
