Aug 16, 2018, 03:49 PM
scratchbuilder
Thomas B.'s Avatar
Trottel's big brother
Here is a preview on the Trottel's big brother, the Honk. It will soon be a free download plan with Modell-Aviator magazine.
Aerobatic cropdusting (1 min 32 sec)
Cologne Waterbombing (1 min 54 sec)
Agrarflieger Testflug (1 min 25 sec)
Aug 16, 2018, 04:17 PM
Team AJ & Twisted!
OliverW's Avatar
I need that plane!
Aug 16, 2018, 04:35 PM
Originally Posted by Thomas B.
I use heat shrink tube and skewers. I make the control horns from short pieces of skewers and the pushrods are skewers ,too. Connections all with heat shrink tube.
I understand regarding skewers and heatshrink regarding servo connection but how do you secure skewers to the deport airleron. thank you.
Aug 16, 2018, 08:40 PM
cbalgra's Avatar
Too much fun Thomas! Great proportions and excellent flying characteristics. Can't wait for the plans for this one! What are you using for motor, battery and prop?
Aug 17, 2018, 12:12 AM
flyin' fool
goldguy's Avatar
I first install the shrink tube on both lengths of bamboo and when still hot pinch the bend with small needle nose pliers or bend over the shaft of small screw driver. Wick in CA glue.
I then glue into control surfaces and adjust the push rod length at the servo end. Color with Sharpie.
Easy, cheap, accurate, smooth operation, bullitproof, absolutely no slop and cheap.
Aug 17, 2018, 05:55 AM
Jim
I printed out the plans and have them taped together. It seems smaller by the plans than it does in the vid's and pics! My plans were a bit shy of the full 600mm. Close enough though! The only material I have is Adams Redi-Board. I'm thinking of peeling off the paper. Any thoughts, suggestions?
Aug 17, 2018, 09:13 AM
Team AJ & Twisted!
OliverW's Avatar
Leave the paper on. It gives the foam rigidity.
Aug 17, 2018, 11:51 AM
flyin' fool
goldguy's Avatar
Remove paper and then tape. Light is MIGHT!! The KFM4 is pretty ridged.
This one is $$ Tree foam board, no paper and no tape …………………. https://www.rcgroups.com/forums/show...6&postcount=28
Aug 17, 2018, 01:20 PM
scratchbuilder
Thomas B.'s Avatar
Motor is 70 - 100g, 900 - 1200 kV , Prop 10x5 to 12 x 4, Battery 3s 2200 to 2600 mAh.
Aug 17, 2018, 02:58 PM
Jim
Aug 17, 2018, 04:55 PM
cbalgra's Avatar
Thanks Thomas! I have a bunch of all that equipment on hand. Looks like I'm going to have to build me a "fool'.
I really like your crop dusting and fire fighting techniques.
Aug 17, 2018, 06:30 PM
flyin' fool
goldguy's Avatar
That's for the bigger Honk. Check the Trottel plan for the recommended equipment.
I'm using a 20 gram Sunnysky 2204/1480 KV, a 10A ESC, 3S 520s spinning a 7X5 and 5.6 gram servos.
BALLISTIC!!!
Aug 17, 2018, 06:34 PM
flyin' fool
goldguy's Avatar
Just cut two more out today in EPP. Got it free from a FB house cleaning his shop.
Saves me slicing up some sheets.
Aug 17, 2018, 06:39 PM
cbalgra's Avatar
BALLISTIC!!!
Got it Frank. That's the size I want to build. The one meter version.
Aug 18, 2018, 03:33 AM
Just realised i have now got a wingspan of 560mm instead of 600mm. My mistake was to measure from the centre line to the wing tip instead of outside of fuselage, never mind.
