That's about the same as mine measured. 560mm....wingtip to wingtip. I'm still on the fence about what adhesive to use. Hot glue is heavy!
I extended the tail moment, so my total length is 20".
Is this the Foam Tac you're using Frank? Looks to be similar to UHU Por.
Thank you, i asked this question because i have seen in other posts that some guys have added a little bit of incidence to the wing after the initial maiden, i suppose if i have too it would only take a sharp knife to release the wing.
My final balance allowed the battery to be mounted here …………..
