Trainer Trottel
It was a rainy and cold weekend, so I built another airplane. This one is based on the Trottel. I built the profile fuselage out of foam from a shipping box, and increased the wingspan to 700mm with a little dihedral for newbies like me. I jokingly call the paint scheme "urban camouflage"
TexasDave, Nice plane , can you please send more picture for the landing gear...i never build one that last. Thanks |
I formed the landing gear from some scrap .032 wire using my soldering iron. I glued a piece of plastic to the fuselage where the gear was to be attached and made some holes through the fuselage with a hot soldering iron. I used pieces of bbq skewers to hold the gear in place. I've had about 10 flights and, so far, it's held up well. Nothing fancy, but it works.
Thanks for the pictures , very ingenious!! Can you share the thickness of the body of the plane? I have a 3/4 in of pink foam that i want to use , and i wonder if it need to be thicker as the plans? Thanks again Alex |
i have a just a Suppo 1804 2480kv motor available I was wondering if that is too small? How is your plane doing with the 1806, good..to small..just correct? Looking forward to see that video. Thanks Alex |
The foam I used was actually from the box my UMX Turbo Timber was shipped in. It is 7/8" thick. The Trottel is so light. I think your 3/4" foam should work fine. Dave |
I am starting my Trottle, i need to learn how to use ailerons..and practice with my son. We just cash a small model warbird because we just fly a 4 channels.
My Jupiter Duck is broken and my Slowly V2 as well. So Trottlel is our next plane. I am using solid body made of 1/2in of pick foam and i also a KFM3 airfoil, i always wanted so see how it flies. I used a dowel and tape to support the wing becuase the dollar tree foam was weak. |
