Holybro Shuriken X1 **Owners Thread** - RC Groups
Oct 17, 2016, 12:00 PM
nitbeat's Avatar
New BNF FPV Racer - already assembled with TMOTOR
Holybro Shuriken X1 F3 DSMX/XSR/Futaba Assemble FPV Racer with 40CH VTX 600TVL Camera BNF
http://www.banggood.com/Holybro-Shuriken-X1-F3-DSMXXSRFutaba-Assemble-FPV-Racer-with-40CH-VTX-600TVL-Camera-BNF-p-1095725.html
- Includes FPV Cam and VTX
- Available option of choosing your receiver:
DSMX Receiver | Frysky XSR Receiver | Futaba
General Information & Tips
Yaw Oscillations Solution (thanks moriwaky)
Originally Posted by moriwaky
here you have all the thing I have done step after step until I have solve my yaw vibration on the shuriken.
1 First I tried playing with PID but inmediatly saw it wasn´t a PID problem.
2 Then I review a blackbox log to ensure the vibration was on yaw axis at 1350 throttle value.
3 I change the notch filter to try overcome the vibrations.. not succes.
4 I added on cli yaw_lowpass = 10 and was little bit better.
5 I figure out that the esc are this one
Read Full Post by moriwaky - Here
NEW Shuriken DIY KIT
Holybro Shuriken X1 200MM FPV Racer DIY Combo Integrated F3 OSD PDB 5.8G 40CH VTX
http://www.banggood.com/Holybro-Shuriken-X1-200MM-FPV-Racer-DIY-Combo-Integrated-F3-OSD-PDB-5_8G-40CH-VTX-p-1120798.html
Descriptions(from banggood)
Shuriken X1 is a high performance FPV racing drone of the latest design from Holybro. Shuriken X1 has FC; OSD; PDB and VTX all highly integrated, which enables us to get all those modules assembled
expediently without additional welding works. The height of this racing drone is very much lower than those conventional X frames, even when it has the Gopro Session mounted on it. Shuriken X1 consists of those components with the best performance and reputation.Just take it out of the box and enjoy the very fierce but yet stable flying!
Specification
Flight Controller : 32-bit F3 Flight Controller , MPU6050 Gyro/Accelerometer
ATmega328P with Arduino Bootloader(minim OSD)
MAX7456 Monochrome On-Screen Display(minim OSD)
FTDI Cable Compatible Pinout(minim OSD)
OneShot125 BLheli S 30A / 40A burst BLHeli ESC's
2305-2600kv Motors (T-MOTOR)
Compact size for 5" propellers, 200mm motor to motor.
Input voltage 7v to 42v.
PCB Maximum Continuous Current 120A
Filtered voltage output - output 5.2v 2A
Weight: About 370g without battery
Features
Full 3K Carbon Fiber
Nickel-plated 12.9 screws
Easy grip black anodized spacers
FC;OSD;PDB;VTX and voltage/current sensor are all integrated in one PCB which makes an integral structure with a much lower barycentre
5.8GHz, 200/600mw switchable, 40 Channel Vtx with built in push button switching and channel display
High quality spiroNet antenna
Intergrated MWOSD (firmware V1.5 preloaded)
1/3 SONY Super HAD II CCD, PAL, 600TVL Camera, 2.5mm Lens
S.bus, DSMX, or PPM Receivers Compatible
3-colour LED board included controlled by LED Trip signal
Two mounting positions for the FPV Camera: one for a 0°~40° view angle, a second mounting position for 35°~70° view angle
Included TPU GoPro Session mount. HD Camera angle 35°
BetaFlight Pre-loaded
Necessary Part(not included)
Battery
Remote Control Transmitter
Oct 28, 2016, 07:33 AM
"Aircraftus Fragmentum"
kydawg1's Avatar
Nice quad, but needs a few changes for strength per RCMODELREVIEWS on Youtube.... check it out.
On the bench: Holybro Shuriken X1 racing drone (14 min 54 sec)
Oct 31, 2016, 04:33 PM
nitbeat's Avatar
https://www.youtube.com/watch?v=zlQ9zdePt74
Nice review !
Oct 31, 2016, 09:31 PM
kydawg1's Avatar
More reviews:
Flight test: Holybro Shuriken X1 drone (OMG it is fast!) (10 min 19 sec)
Shuriken X1 Review Holybro. Full BNF Review + Flight (21 min 31 sec)
Nov 01, 2016, 07:48 AM
hey guys, yeah i just made a new topic about this quad, best to delete my topic . i have seen this aswell, and it got my interest. hope to see that they fix the little issues, with for example the camera, so that you can get to it better. but this quad looks amazing
Nov 01, 2016, 04:02 PM
some questions about the quad, do you know the target for the flight controller to update betaflight? Can you configurate the OSD to show you the mah consumed? and the last one Do you know if the esc will be compatible with the new protocol dshoot? Dshoot seem far better than multishoot. thanks folks
Nov 02, 2016, 03:26 AM
Based on Joshua Bradwell's video BLHeli_S supports Dshot so the ESCs will support it.
Nov 04, 2016, 08:59 PM
kydawg1's Avatar
For sale Gearbest also...
http://www.gearbest.com/multi-rotor-...32.html?wid=21
We need some discount codes...
Nov 04, 2016, 09:18 PM
(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)
JohnCC's Avatar
Don't forget RC18OFF coupon works on it, at least for now.
Latest blog entry: Drones for Christmas! 🎅
Nov 07, 2016, 06:41 AM
kydawg1's Avatar
I cannot get that 18% discount to work...says not allowed for this item.
My account would not allow.... so opened new account and it worked. Would not work with already on sale DSMX at $259.... only with the FRSKY or FUTABA versions showing $301... then discounted with code to $247.
Nov 07, 2016, 03:22 PM
So what I've seen this is a bad azz quad. WAY TOO MANY choices come tax time, speed addict 180/210R, speed addict super light, stigg 195, qav-r, charpu, holy bro x1....and on and on. Ughhh.
Nov 10, 2016, 08:02 AM
yeah baby
i ordered mine yesterday,
hope to see it soon in my mail
i can't wait
Nov 11, 2016, 05:12 AM
nitbeat's Avatar
i can't wait
Congrats, hope it'll be a treat for ya !
Nov 17, 2016, 04:02 PM
binding
tnx Nitbeat,
i got her on the table wright now
and she looks amazing
the only problem i got wright now, is that i can't
seem to bind her, or i got something wrong in the settings
but i tried to see if i see anything in betaflight. but it all looks ok
a red led on top keeps flashing, and a green led in front is solid.
after a couple of flashes from the blue led next to it.
through my goggles i see that she is disarmed, but i didnt even install the lock and unlock
what i have done, is put a firmware on my taranis to get d8 mode
because i got the qx90 wich needed that, could that be the problem.
i tried binding it with d16 and d8 but nothing helped.
hope someone here can help me
best regards Raver
Nov 20, 2016, 04:42 PM
euro or international
when you order at Gearbest,
do you get the international firmware on the frsky receiver
i got a euro taranis, although i flashed it, so that i can bind with D8
but maybe it is still euro so is there a possibility that that could be the problem?
i still can't bind with my shuriken x1
what i do see is, that the red led on the receiver keeps flashing
but when i try to bind it stays red and another green.
in the manual it says that the led needs to flash and then you are in bind mode
is there someone here who got some info please?
thanks in advance
