This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Oct 16, 2016, 04:33 AM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
New Product
New DJI HEX Charger for Inspire1, M600,M100
DJI Have finally released their new multipack charger, the DJI Hex Charger is designed for use with dedicated Intelligent Flight Batteries and Remote Controllers. It can charge up to six Intelligent Flight Batteries and two Remote Controllers simultaneously.
This can be purchased from the DJI Store for 289/$299 below
Order Now DJI Store
See bottom of page regarding these links for more info
Specifications
Model: MC6S600
Compatible Battery:
Inspire 1 Series Intelligent Flight Battery (TB47/TB48)
Matrice 100 Intelligent Flight Battery (TB47D/TB48D)
Matrice 600 Intelligent Flight Battery (TB47S/TB48S)
Compatible Remote Controller:
Inspire 1 Series Remote Controller
Matrice 100 Remote Controller
Matrice 600 Remote Controller
Lightbridge 2 Remote Controller
Phantom 4 Remote Controller
Phantom 3 Professional/Advanced/4K Remote Controller
Operating Temperature: 32 to 104 F (0 to 40 C)
DC Output: 26.1 V; 0 to 3.83 A (Battery Port); 0 to 2 A (Remote Controller Port)
Weight: 2140 g
Looking at the spec it charges at 3.83A so i would say a TB47 would charge in about 1h45m and around 1h20 for a TB47, there is no info on if it has storage charge or other features as of yet.
DJI have also released a nice carry case that will hold 2 x Hex chargers allowing you to charge up to 12 packs at once.
The Matrice 600 Battery Travel Case can hold up 2 DJI Hex Chargers and 18 Intelligent Flight Batteries (TB47S / TB48S / TB47D / TB48D). Integrated wheels make the travel case easy to maneuver. Using the reserved spaces, batteries can be charged without removing batteries or chargers from the travel case.
This case can also be purchased from the DJI Store for 291/$299 below
Order Now DJI Store
Specifications
Dimensions: 860 mm 560 mm 455 mm
Net Weight: 10.5 kg
Max Internal Load: 18 kg
Compatible Batteries: TB47S / TB48S / TB47D / TB48D Intelligent Flight Battery 18 pcs
Compatible Chargers: MC6S600 (DJI Hex Charger) 2 pcs
Operating Temperature: -10 to 50 C
Note external links on this page contains affiliate link and i may receive a small commission from any purchases made through it, you can choose to avoid them by just navigating to the DJI Store manually.
