Aug 31, 2018, 12:59 AM
hawaiianspork226's Avatar
Got the flap mounts designed and printed. Did the outer ones today, I'll print inners tomorrow. Wasn't quite happy with the inners but they're good to go now
-david
Sep 02, 2018, 11:42 AM
kellanplanes
This is looking great!!! I am looking forward to seeing how this flies!
Sep 15, 2018, 10:21 PM
Not much done the last few weeks. Been out if town a lot and work got intense too...
But today I got a new nosegear plate cut. Hopefully more progress tomorrow.
-david
Sep 17, 2018, 12:12 PM
kellanplanes
Hey thats okay! Just keep us updated whenever! Awesome plane so far!!!!!
Sep 19, 2018, 05:57 AM
Warbirds Lover
Dreamcatcher's Avatar
Hi folks,
Very interesting project, i take a chair and will follow the next steps !
Cheers
Sep 20, 2018, 01:24 AM
Got the hatch covers cut along with the pieces that will become the "spludders". Plan is the bag the spludders halves to a piece of window glass with low vac pressure so as not to crush the foam - EPS doesn't do well with high vacuum...
Also got the main landing gear mounting plates cut
-david
Sep 23, 2018, 06:29 AM
mike_o's Avatar
Very nice work - subbed and looking forward to see the progress!
Sep 27, 2018, 12:25 AM
working on the back end a bit - lots of work goes into the CAD for this model before it happens in reality... but i did take some screenshots
clean and dirty flight modes depicted from several angles. didnt set all the colors right yet...
-david
Sep 30, 2018, 05:32 PM
Little bit as often as I can...
Got some new flap hangars printed and fitted. Thanks Mike for printing them out for me - he printed them out of carbon filled PLA - should hold up better to heat, and they are printed slightly hollow - so they ended up about 30% lighter too.
Mike is one of the guys printing complete 3d printed planes, on the bleeding edge of the hobby, and just happens to be on my way to and from work here in San Diego. He will print you parts or a complete airframe if you like, hit him up if you're interested. Super cool stuff, the future of scratch building really, or at least a large part of it.
Mike's handle here on rcgroups is "electric-2000"
david
Oct 09, 2018, 12:02 AM
Finally got the flaps sanded in so that they retract all the way up.
Not much progress this weekend. Was at the shop quite a bit but we had some major cleanup going on. Time to purge some stuff.
-david
Oct 09, 2018, 04:23 PM
Right Rudder
PittSpecial's Avatar
Nice!
Can't wait for the Maiden!
Oct 10, 2018, 02:35 AM
Warbirds Lover
Hi !
Are you using a 3D mill to "sculpt" so clean foam pieces ?
Impressive work, congratulations
As PittSpecial, I also can't wait for the maiden
Oct 10, 2018, 04:49 AM
rajazo's Avatar
Wow this is one of the cleanest and professional foam build I ever see, and the aircraft locks fantastic.
The only sad part is that the build process is difficult to replicate because the lot of machinery involved.
Anyway a pleasure to follow
Btw, Can you post more details about flap mechanism?
Oct 10, 2018, 12:27 PM
Originally Posted by Dreamcatcher
Hi !
yea im using a CNC router for cutting the foam parts out - the process goes like this:
design plane
divide plane into chunks that will be easily machinable on a 3 axis CNC router
cut foam pieces on CNC router
assemble chunks with stiffeners / spars where necessary
sand parts to match eachother (should be pretty close already tho because CNC routers are pretty accurate
apply lightweight filler
sand smooth
glass with whatever weight cloth is appropriate (i used 4oz for most of this plane, which is kinda heavy for this size airframe... but i do NOT plan to be kind to this airframe)
sand
fill
sand
prime
sand
fill
sand
prime
sand
fill
sand
prime
sand
paint
sand some more
paint some more
theres still a lot to do for 3d printed components too... but im working that
-david
