Stryker VTOL - RC Groups
Oct 13, 2016, 03:53 PM
kasra's Avatar
Build Log
Stryker VTOL
Hello, I am going to post details in this thread on the Stryker VTOL design I built last year and it has proven as a very nice flyer. I want to give full credit to Leadfeather where I got the idea:
https://www.rcgroups.com/forums/show....php?t=1565831
I can get 10 minutes on a 1300 pack. The plane weighs about 1 lbs with the battery pack.
Here is a list of parts:
Elevons : 2 5 gram servos
Motor tilt: 9 gram metal gear servo
tail rotor tilt: 5 gram metal gear servo
recevier: Spektrum 6 channel AR6100e
ESC's: 10-12 A simonK software optional
Flight Controller: NanoWii board from HobbyKing running MultiWii software
Motors: HXT2730-1300 KV brushless motors or equivalent 24 gram motors
Battrey: 1300 3S 30C+ battery
Also need a V-Tail mixer
Some flight videos:
Stryker VTOL (1 min 53 sec)
More Stryker VTOL Flying (2 min 57 sec)
Oct 13, 2016, 04:48 PM
Up! Up! And Away!
GottaZoom's Avatar
Awesome! Looking forward to pics and any more mount or setup info, if possible.
Something special in the multiwii firmware for VTOL, or will some of the newer multi-rotor flight controllers work? Happen to have an unused Stryker fuselage and micro CC3D available ....
Oct 13, 2016, 05:03 PM
Ran D. St. Clair's Avatar
I've seen it fly and it is a sweet plane.
Oct 13, 2016, 10:48 PM
RCvertt's Avatar
It appears to transition smoothly.
Oct 14, 2016, 05:41 AM
Winging it >
leadfeather's Avatar
Nicely done kasra!! Looks like you've done a great job with the tuning! If flys great!!
Which version of the multwii code did you use?
Why did you need a V-tail mixer? Are you running the elevon servos directly from the Rx?
Oct 14, 2016, 10:43 AM
kasra's Avatar
Thank you. It does fly well. I am still using the modified 2.2 software. I will shortly post links to the exact products I used. I did a tally one time and everything including the airframe was around $100. I am using the V-tail mixer since I am running the elevon servos directly off the RX. In forward flight, I turn off the stability completely. There are three modes.
With HobbyKing selling $5 KK2 boards, now might be a good time to switch to Open Aero code.
Latest blog entry: Car Show
Oct 14, 2016, 11:44 AM
I'd be mad without a Taranis!
Rups63's Avatar
Are you planning on posting a more detailed build procedure?
Oct 14, 2016, 12:24 PM
kasra's Avatar
Absolutely and I can program the NanoWii board and provide it also. Not sure if HobbyKing still sells those. I will try to do the detailed parts list this weekend and we go from there.
Oct 14, 2016, 04:27 PM
That is brilliant, I am looking forward to seeing the details of how you built this one!
It'll be my next project.
thanks
spud
Oct 14, 2016, 09:35 PM
Rups63's Avatar
I'm really looking forward to this as well! I have a spare stryker frame that I want to use for this project.
Oct 15, 2016, 08:08 AM
jimjim06's Avatar
Very cool build!
Im not really into Quads or helicopters, but this looks lik a perfect mix of plane and multi rotor!
Thanks for sharing!
Jimjim
Oct 15, 2016, 10:19 AM
rohan67's Avatar
Motors: 2811-1300 KV brushless motors
Some flight videos:
https://youtu.be/aMv91B0Ihhs
https://youtu.be/UUKlRBA4Uxs
Very cool plane.
Oct 15, 2016, 10:39 AM
rohan67's Avatar
Where in europe,to find stryker airframe?
Oct 15, 2016, 11:44 AM
rajazo's Avatar
Amazing plane... enought speed , great performance and rock solid hover.... I hope to see more info soon ... what mixes on radio, fc setup; CG position lot of question... for sure your setup will work on a scratchbuilt frame version...
Please post more details soon
Oct 15, 2016, 01:49 PM
Up! Up! And Away!
GottaZoom's Avatar
Will have a look at the KK boards again.
Really interested in the motor tilt mechanism - hard to see on the other thread you referenced.
So, for forward flight you are turning off the MWii? So, is this essentially a SLT setup where the motor and elevons run unstabilized off the RX in forward flight, or is that just a preference for a particular flight mode?
