Nov 04, 2016, 07:56 PM
Telemetry wires is needed
Nov 04, 2016, 07:58 PM
Fly it like you stole it!
DaZa_AU's Avatar
Originally Posted by juuuut
i found one tiny change.. i did you a special T10.7 (xx) with only that changed back .. i dont think that it does much .. but would be good to know
regards
Felix
Hi Felix,
Just tried this version as well on DAL tri-blades using DShot600 and resonance is pretty much gone now as well around 30-40% throttle.
Great to see more progress coming though, keep up the excellent work!
Nov 04, 2016, 10:16 PM
OSD on the fritz after update
doing weird things ARM switch is toggling between simple and advanced and readings are wrong
Nov 05, 2016, 02:13 AM
Any advice for my setup:
Xracer F303 v3.1
DALRC BS25a (EFM8BB2 50MHZ)
Zmx Fusion X25 2300kv
Which files should I pick?
Nov 05, 2016, 04:43 AM
sniperxnl's Avatar
i have flashed today the latest fc fw and the latest esc fw. i select d600 and only 3 motors are spinning.
setup
kiss fc and kiss 24a
stock settings
Sent from my Redmi Note 3 using Tapatalk
Nov 05, 2016, 05:04 AM
sniperxnl's Avatar
setup
stock settings
kiss dshot (0 min 14 sec)
Nov 05, 2016, 05:06 AM
SadLeprechaun's Avatar
Fascinating thread. Read through some, and it is a little complex for me, so I will just ask . .
Is there a list of ESCs other than KISS that work/will work so far? I am going to be building a new drone soon and I wanted to future-proof it so it is ready for Dshot. I guess I mean, what are the ESC requirements?
Using BluejayF4 and DYS XS30 on my current main rig . . sadly someone mentioned XS30 not working, at least I am using the right FC. ;(
I would love some good answers here please!!
Nov 05, 2016, 05:16 AM
Team Armattan
lux 3.1 656 and Dshot
ok i try some configuration and work well only with Dshot 150
Lux Official
Esc RSv2 30A
loop time 4k/2K and esc unsinc 32k
cpu load if 8k/8k 100 percent dont work
any suggestion
Nov 05, 2016, 05:40 AM
https://youtu.be/4zjKqCA1Jm0
did you checked teh ESC's version in ESC flasher tab? mybe thet one ESc dont got flashed or was flashed with a failue (simply repet in that case)
BTW you can also switch to oneshot and have a look at the ESC's FW version
regards
Felix
Nov 05, 2016, 06:50 AM
Sniperxnl are you using the Cobra Champion 2205?
If so you run the same setup as I do.
(Plus i live like 5-10 minutes away from you xD)
Can you check the firmware versions in the flasher tab?
Can you see/hear the ESC initialize?
I had semi the same issue when I flashed my ESC through the newest FC FW, but all of mine just refused instead of one.
Nov 05, 2016, 07:03 AM
Ok mate, someone just put a spoke in the wheel of it being an esc issue.
I have bluejayf4 working with Aikon semf v1
Mrmurder also have a bluejay with racerstar v2s and it isn't working
QMF has some escs that work and some that don't, the ones hat don't behave the same as mrmurders rig.
But someone on BF thread has it working with the same escs as mrmurder
So it looks like the issue is more complex than just some types of escs won't work
Best suggestion is flash the escs and the FC and try it
Nov 05, 2016, 07:35 AM
Hmm ok, perhaps this weekend I will give it a go. Only my top quad has a Bluejay so it is a bit scary to go for it on my main top rig but I guess in the spirit of innovation I will give it a go, worst that can happen is I need to reflash my ESCs.
Is it as simple as loading up the beta Betaflight version (lol) and then change the CLI value for which esc protocol, and update the ESCs to the Dshot FW?
Nov 05, 2016, 07:45 AM
sniperxnl's Avatar
regards
Felix
I can;t see the fw version only --.
Do i need to connect the telemtry wire for that?
I have flashed is again, but nothing happend
When i use Oneshot all motors spins
Nov 05, 2016, 07:47 AM
sz4dy's Avatar
I just did about 10 packs with kiss fc, kiss 24, 107xx. Smooth as butter better than any fw before
Nov 05, 2016, 07:56 AM
sniperxnl's Avatar
Hmm when i flashed the esc's again, One esc get no blue leds blinking. Maby this one have the old stock firmware
I d solder the bridge for selecting the motor direction and flash again. now it blinks
