Thread Tools |
This thread is privately moderated by XQPOWER, who may elect to delete unwanted replies. |
Yippee!
Highly recommend Digital Servo
Hi guys ! nice day ?! some one 's looking for the models below ?
Yes , really hot model ! XQ-S4116F Name:15kg-cm Digital Servo; Size :A:40.2mm B:20.1mm C:38.8mm D:48.0mm E:10mm; Weight:56g ±0.2(1.46oz); Gear type:Titanium Gear; Speed:0.08 sec/60° at (7.4V) 0.10sec/60°at (6.6V) Torque208.3 oz-in)15kg.cm.at(7.4V) (180.5 oz-in)13kg.cm.at(6.6V) Digital servos features: Support high voltage;Waterproof; Plastic case, resist heat and corrosion; Aluminium middle hull, easy to eliminate heat;Adopt high quality coreless motor. XQ-S4116D Name:8.5V16kg-cm Digital Servo; Size :A:40.2mm B:20.1mm C:38.8mm D:48.0mm E:10mm; Weight:56g ±0.2(1.46oz); Gear type:Titanium Gear; Speed:0.14sec/60º at (7.4V) 0.12sec/60º at (8.5V) Torque205.5 oz-in)14.8kg.cm.at(7.4V) (234.7 oz-in)16.9kg.cm.at(8.5V) Digital servos features: Support high voltage;Waterproof; Plastic case, resist heat and corrosion; Aluminium middle hull, easy to eliminate heat;Adopt high quality coreless motor. |
