This thread is privately moderated by santanig5, who may elect to delete unwanted replies.
Oct 07, 2016, 01:16 PM
Ghost Rider the pattern's full
santanig5's Avatar
Build Log
Rochobby Super Scorpion 70mm edf jet - pnp
ROCHOBBY SUPER SCORPION 70MM EDF JET - with SAFE Receiver
Wingspan - 830mm / 32.7in
Length - 960mm / 37.8in
Flying Weight - 1020g / 36.0oz
Power System - Brushless 2845-2750KV
Speed Control - 70A, T Connector
Propeller / EDF - 70mm 12 Blade EDF
Servos - 4x 9gram Digital Metal Gear Servos
Landing Gear - None
Required Battery - 4 Cell 14.8V 2500mAh LiPo (required)
Required Radio - 4+ Channel Full Range (required)
Rudder - No
Flaps - No
Ailerons - Yes
Lights - No
Hinge - Type Foam
Material - EPO Foam
Build note: I used a soldering iron to create a wire trough for the elevator servos.
E-Flite SAFE Conversion
Rx mounted on top of the wing.
In-line reverser required for Elevator
Added Skid Guard Safey Tape to grip.
Covered with 3M Paint Defender for high gloss finish.
YouTube Playlist
https://www.youtube.com/playlist?lis...jDS7huAGpw8poL
Oct 30, 2016, 04:27 PM
santanig5's Avatar
Update: As the EFLR310013 Apprentice SAFE Rx would not allow past 1/2 throttle before the plan began to oscillate horribly, I deiced to try the SPMAR636F4U Corsair SAFE Rx, it was better, allowed for 3/4 throttle before oscillation.
I plan to try Spitfire SAFE Select Rx next time out.
Jul 22, 2017, 03:26 PM
Santanig5,
I like you Super Scorpion 70mm EDF SAFE conversion.
I have done a similar conversion with my 4S Freewing Stinger 64mm EDF.
I'll have to check at what throttle the oscillations happen...I guess I probably just naturally ease up on throttle when it happens
I have similar problems with oscillations at higher throttle...do you know why this happens with the safe receiver?
Did you ever try the Spitfire SAFE rx?
I wondered if it was better than the Corsair
-David
Jul 22, 2017, 05:17 PM
santanig5's Avatar
Originally Posted by razzy8
Santanig5,
-David
The Spitfire Safe Select Rx is definitely better than the Corsair, but still has oscillation at higher speeds, I suspect due to the pre-programed gain settings.
For now no way to change the Safe settings, but maybe one day.
You may want to try a basic Rx with a different stabilization system where the gains can be adjusted if you need it now, there is plenty of room for two units.
GJS
Dec 25, 2017, 01:13 PM
santanig5's Avatar
Super Scorpion bungee launch (3 min 54 sec)
