Thread Tools |
This thread is privately moderated by FPV.Model, who may elect to delete unwanted replies. |
New Product
Alpha200 Racing Quad Newly Released ==> FPVModel.com
Alpha200 Racing Quad:
http://www.fpvmodel.com/alpha200-200...ard_g1197.html Alpha200 is an X style race frame designed with strength in mind. This bare bones racers is a simple x style unibody design with a small footprint. Keeping strength in mind we have left out the cut outs that usually add weight reduction and an estetic appeal and decided wed make up the weight reduction by focusing on a smaller frame while leaving enough area to still comfortably install all the components for the build. This frame features routed edges that gives a smooth rounded surface to all edges of the carbon fiber which helps eliminate delaminated edging for those unavoidable strikes that everyone experiences....making this a perfet choice for those that are looking for a simple, durable, and lite frame. The camera mount features an easy lockable mount that will hold the likes of HS1190 or swift style cameras at the angle you choose when you build it. Besides, we have listened to a lot of racers and include a 3D printed part to protect the antenna and power cable. The Alpha200 has high quality 4mm bottom plate and a 2mm top plate. Using the same 3K carbon fiber of our ZMR series airframes and KL200RACE frames, you can rest assured that Alpha200 is stronger and much more durable than most of the frames on the market. Alpha200 is an alpha frame and you will notice it holds up to its name when you testing the ability to show off its strength. Specs & Features - 4.0mm Main Frame - 2.0mm Top Frame - Aluminum Anodized & Stainless Steel Hardware - 98 Grams only (Including Frame, PDB and Hardwares) |
