This thread is privately moderated by schumixmd, who may elect to delete unwanted replies.
Sep 29, 2016, 08:56 AM
schumixmd's Avatar
New Product
REDCON CM703 2.4G 7CH DSM2 DSMX Compatible Receiver With PPM Output
Hi everyone,
Lately REDCON started to release a bunch of different receivers for different brands. They got my attention just because they are much more affordable that original receivers.
The latest receiver I was offered to review by Banggood is REDCON CM703 2.4G 7CH
This is a 7ch DSM2/DMSx receiver with PPM out, which is the best feature of this receiver in my opinion, and at 8$ - let's agree it is more than affordable and a good competitor for all other compatible receivers.
Some specs borrowed from the site:
Brand Name: REDCON
Item Name: CM703
Band: 2.4G
Channel: 7
Operating Voltage: 3.3V-9.6V
Modulation: DSM2/DSMX
Dimensions: 47 x 24x14 mm
Weight: 10g (4.8g Naked)
Brown-Out Voltage: 4.0v (Always supply power above this voltage)
Antenna Length Main RX: 13.5cm (2)
Expected Range: 800m (tested with JR DSX9)
PPM Output: Yes (support RC multicopters)
Compatible Transmitter: JR and Spektrum DSMX DSM2 transmitter
Output: 7 channels with PPM Output
Antenna gain: 3dbi gain antenna, 15dbi gain amplifier.
Features:
Stronger anti-interference ability and farther control range.
Patent pending Model Match prevents flying a model using the wrong model memory (feature does not work with module systems)
Servo Sync (feature does not work with module systems)
Preset failsafe system
Quick Connect
Compatibility (Spectrum and JR DSM2 /DSMX): DX6I,DX7,DX8, DSX7,DSX9 DSX11
My test receiver is on the way. So, about the quality and real life test I will come back later.
Sep 29, 2016, 08:57 AM
schumixmd's Avatar
All the discussion should happen in the original forum thread.
https://www.rcgroups.com/forums/show....php?t=2731284
New Product REDCON CM703 2.4G 7CH DSM2 DSMX Compatible Receiver With PPM Output schumixmd Radios 77 Mar 30, 2019 11:58 AM
