Sep 29, 2016, 07:54 AM
New Product
Smart Drone SMD Red Arrow Racing FPV /w 720P Camera RTF Foldable Drone - $340
more details: http://www.banggood.com/Smart-Drone-...p-1091696.html
Description:
Aircraft
Weight: 550g (including battery and propeller)
Diagonal Size: 250mm(not including propeller)
Max. Flight Altitude: 100m
Max. Attitude Angle: +/- 30°
Max. Ascent Speed: 3 m/s (ATTI Mode)
Max. Decent Speed: 2 m/s(ATTI Mode)
Max. Speed: 20m/s
Max. Altitude: Above Sea Level 4000m
Communication Equipment: 2.4GHz remote control Signal 5.8GHz Analog Image Transmission Signal
Operating Temperature: -10 °C ~ +45 °C
Max. Flight Time: 15 min.
Motor: 2204 Blushless Motor KV2200
ESC: FOC 15A
Camera & Image
Image Sensor: CMOS
Electronic Shutter Speed: Automatically
Image Resolution: 1280*720
Video Resolution: 720P @30FPS
Supports Memory Card: TF Card, Standard with 8GB, Max. supports 32GB
File Format: Video:avi Image: jepg
Operating Temperature: -10℃ ~ +45℃
White Balance: Automatically
Image Transmission Operating Voltage: 12V
Operating Current: 250mA
Frequency: 5.8GHz
Image Effective Distance 150m
ISO: Automatically
Sensor
Three axis magnetic compass, Three axis gyroscope, Three axis accelerometer and barometric sensor
Remote Controller
Channel: 8CH
Operating Frequency: 2.4GHz
Control Range: 300m
Battery: 5000mAh 2S Rechargeable Lithium Battery
Image Transmission Display: Image Transmission Receiver Display Integrated Design
Equivalent Isotropic Radiated Power: 20dbm
Operating Current/Voltage: 1.1A/7.2V~8.4V
Low Battery Level Warning: <6.8V
Remote Controller Charger
Input Voltage: 220V
Rated Power: 100W
Intelligent Battery
Battery: LiPo 3S 12V / 2200mAh
Power: 25Wh
Max. Charging Power: 500W
Battery Weight: 195G
Intelligent Battery Charger
Input Voltage: 100~240V
Rated Power: 37.5W
Features:
1. ALL IN ONE Design, Ready-to-Fly Out of the Box!
Simple, Sexy, Stylish, the best ALL IN ONE Design Racing Drone that EVERYONE CAN FLY. An integration design of body, flight controller, power system, just need to unfold the motor arm and secure them and then install the propeller. You do not need to finish the completed assembly of the aircraft by yourself and it just take you about 2 minutes to prepare for your first fly out of the box.
2. Foldaway Arms, Easy for Transportation
The Red Arrow is a reasonable size Racing Drone with a simple, foldaway arms body structure design, making it possible to drop it into a backpack and can be easily to carry and transport.
3 . Stabilization Controller, Optimization Algorithms for Racing Drone Platforms.
The Optimization Algorithms on the controller by providing a multiple flight modes, suitable for the beginner and also for the Intermediate and Advanced pilot to experience different flight speed and enjoy the fun from flying the Red Arrow.
4.Powerful Brushless Motor, Enjoy the Passion of Speed.
Configured with high efficiency brushless motor to provide a fast speed, the maximum racing speed is up to 20m/s. Built in with 3S intelligent Li-poly battery, flight time up to 15 minutes.
5. Sensitive Joystick Control, Perfect Operation Experience.
Configured with a unique & professional remote controller, sensitive joystick control and dial switch design, enable the pilot to experience a better interaction with the Red Arrow and enjoy a perfect control experience during each flight. The remote controller also can be realized one key take off and one key landing easily.
6.Intelligent Orientation Control (IOC)
Usually, the forward direction of a flying racing drone is the same as the nose direction. By using Intelligent Orientation Control (IOC), wherever the nose points, the forward direction has nothing to do with nose directions. IOC is a very useful tool which can help you archive that perfect shot or just for getting you out of a sticky situation.
7. Beginner Flight Mode
Just toggle the flight mode switch to the beginner flight mode position and the beginner pilot will be able to experience the soft flight speed and learn how to fly a racing drone in a safe and an inexpensive way.
8.Real Time Video Transmission
Built-in with 5.8G analogue video transmission module, including a ground monitor receiver display, enable an ultra-low latency video transmission.
9. Colorful Rear Lights, Flight Status Indicator
The Front LEDs show the orientation of the aircraft and the rear LEDs show the aircraft Status Indicators. The screen on the Red Arrow is the colorful rear lights and the pilot can set up the favorable color before they take off the aircraft. When the pilot do a maneuver brake of the aircraft, the screen will display red.
10. Multi-function Remote Controller
Configured with an 8ch multi-function remote controller, provide with IOC, Advanced & Beginner three flight modes. The pilot also can realize to take a photo and video record easily from dialing the relative buttons on the remote controller. The control range of the radio is up to 300 meters.
Package included:
1 x Red Arrow Racing with Camera
4 x Propeller
1 x Transmitter with image screen
1 x Charger
1 x Battery
1 x Manual
