Realacc GX210 CC3D/Naze32/F3 Racer /w 700TVL Camera & 40CH VTX ARF/RTF - $103/190 - RC Groups
Sep 27, 2016, 11:31 PM
New Product
ARF version: http://www.banggood.com/Realacc-GX210-CC3D-Naze32-F3-FPV-Racer-RTF-with-700TVL-Camera-40CH-VTX-p-1091154.html
RTF version: http://www.banggood.com/Realacc-GX210-CC3D-Naze32-F3-FPV-Racer-RTF-with-700TVL-Camera-40CH-VTX-p-1091154.html
It's essentially a prebuilt QAV-X clone with Racerstar BR2205 2300KV motors and 20A Racerstar BLHeli_S ESCs
specifications:
Description:
Brand Name:Realacc
Item Name: GX210
Item Specification Features
Realacc GX210 Frame Dimension:180 x 180 x 95mm
Weight: 294g (without battery prop)
412g(with battery)
Take off Weigh: 412g
Package Weigh: 1.28kg
Compatible with 5 inch propeller
Compatible with 2205 motor
Can be used with 4S/3S battery
With direction indicator LED
ESC
Brand Name: Racerstar
Item Name: 20A BLHELI_S ESC Electronic Speed Controller
Model: RS20A
Con.Current:20A
Peak Current(10s):25A
Input Voltage: 2-4S
BEC: No
Programming : YES
Firmware: Blheli_S
Weight:7.9g
Size(PCB):27*12mm With Blheli_s Firmware
With 24MHz BB1 Clip
Support Oneshot42 Multishot
Smaller size and lighter
Strong adaptive ability
Motor
Brand: Racerstar
Item name: BR2205 2300KV Brushless Motor
RPM/V: 2300KV
Height: 31.5mm
Width: 27.9mm
Shaft diameter: M5
Motor mount hole size: M3
Weight: 28 grams
Voltage: 2-4S
Battery: 2-4S lipo battery
Max.current: 27.6A
Max.power: 408W
Internal resistance:Ω
Usage: for 250 260 280 Multirotor Frame Kit
Flight
Controller CC3D / Naze32/SP Racing F3
Battery 3S 11.1V 1500mAh 25C Battery ,XT60 plug
700TVL Cam Power supply: 3.6-5.5V (powered off TX)
Power consumption: 60mA @5V
Imager: 1/3” CMOS, more than 700TVL
Angle: 127° diagonal FOV, 110° horizontal FOV
FPV tuned light handling
NTSC or PAL (selectable; jumper on = PAL).
Lens: 2.6mm IR coated
FOV: 127°diagonal 110°horizontal (ideal for fixed camera)
Operation Temperature: -20 to 70°C
Square: 32 X 32 X 23.5mm
Lens extrude (LxDia): 15mm X 14mm
Weight: 12g
FT200 VTX Modulate: Wideband FM Modulate
Video Format: NTSC/PAL
Output Impedance: 50 Ohm
Output Power: 23-24dBm
Channel: 40 CH
Operating Voltage: 7V-24V
Supply Current: 190mA
Operating Temperature: -10~85 Video Band Width : 0~8.0 MHz
Audio Carrier Frequency: 6.5 MHz
Video Input Level: 0.8~1.2 Vp-p
Video Input Impedance: 75 Ohm
Audio Input Level: 0.5~2.0 Vp-p
Audio Input Impedance: 10K Ohm
Transmitting distance : ~300m (open area)
LED indicators for Fr/Ch
Connector: RP-SMA Female
Antenna : RP-SMA Male,LHCP
Dimension: 38mm x 22.5mm x 6mm
Weight: 6g (without antenna)
Frequency and channel frequency table:
CH CH 1 CH 2 CH 3 CH 4 CH 5 CH 6 CH 7 CH 8
GROUP
A 5865 5845 5825 5805 5785 5765 5745 5725
B 5733 5752 5771 5790 5809 5828 5847 5866
C 5705 5685 5665 5645 5885 5905 5925 5945
D 5740 5760 5780 5800 5820 5840 5860 5880
R 5658 5695 5732 5769 5806 5843 5880 5917
i6
Transmitter Channels: 6 Channels
Model Type: Glider/Heli/Airplane
RF Range: 2.40-2.48GHz
Bandwidth: 500KHz
Band: 142
RF Power: Less Than 20dBm
2.4ghz System: AFHDS 2A and AFHDS
Code Type: GFSK
Sensitivity: 1024
Low Voltage Warning: less than 4.2V
DSC Port: PS2;Output:PPM
Charger Port: No
ANT length: 26mm*2(dual antenna)
Weight:392g
Power: 6V 1.5AA*4
Display mode: Transflective STN positive type,
128*64 dot matrix VA73*39mm,white backlight.
On-line update:yes
Color: Black
Certificate: CE0678,FCC
Model Memories: 20
Channel Order:
Aileron-CH1, Elevator-CH2, Throttle-CH3,
Rudder-CH4,
Ch 5 & 6 for reserve Works in the frequency range of 2.405 to 2.475GHz.
Uses a high gain and high quality multi directional antenna
Each transmitter has a unique ID
Low power electronic components and sensitive receiver chip.
AFHDS2A system has the automatic identification function
AFHDS2A has built-in multiple channel coding and error-correction
User Manual
iA6
Receiver Channels: 6 Channels
Model Type: Fixed-wing/Glider/Airplane
Bandwidth: 500KHz
Band: 142
RF power:less than 20dBm
RF.receiver sensitivity:-105dBm
Code Type: GFSK
ANT length: 26mm
Weight:6.4g
Power:4.0-6.5V
Color: Black
Certificate: CE,FCC
i-BUS port: NO
Data Acquisition port:NO
Package Included:
1 x Frame Kit
4 x Racerstar BR2205 2300kv Motor
4 x Racerstar Blheli-S 20A ESC
1 x Flight Controller
1 x Power Cable
1 x PDB
4 x LED(2 x Blue,2 x Red)
1 x 700TVL Camera
1 x 40ch 200mW TX
1 x Camera Mount
4 x Sponge Feet Pad
1 x Battery Tie
1 x Battery Board
1 x 3S1500mAh Battery
1 x B3 Charger
8 x 5inch Prop
1 x RP-SMA Antenna
1 x Flysky i6 Transmitter
Sep 28, 2016, 02:26 AM
New images !!
Realacc GX210 CC3D / Naze32 / F3 FPV Racer RTF with 700TVL Camera 40CH VTX (1 min 40 sec)
Sep 28, 2016, 08:31 AM
campfir3's Avatar
Wow this looks like it could be a winner, love the X Frame.
Sep 28, 2016, 02:31 PM
aka RCFlyer85
Irock1985's Avatar
Definitely looks nice.. Hopefully I can get to test it out
Sep 29, 2016, 09:22 AM
Aaron qin's Avatar
it will be in stock next week
Sep 29, 2016, 01:41 PM
aka RCFlyer85
Irock1985's Avatar
Any review units going out?
Oct 06, 2016, 12:24 AM
These have just been released. Both the ARF and RTF in CC3D, Naze32 or SPF3.
Problem is. These have the v1 BlHeli_S ESCs. Didn't those have De-sync issues? If they're solid then these are a bargain. The 210 kits come with the v2 ESCs.
Oct 06, 2016, 07:50 AM
campfir3's Avatar
Sickocrow, how can you tell these have the v1 BLHeli ESCs?
Also, what kind of differences would one notice from the three different flight controllers? I see the SPF3 is a little more, is there a benefit of this one?
Oct 06, 2016, 08:55 AM
It's listed in the parts. "20A BLHELI_S ESC Electronic Speed Controller". It's listed as the v2 versions in the X210 kits. The Racerstar v2 escs have a big red V2 in the top left corners. The v1s don't. The F3 board has more CPU grunt then the other two, and is a newer design. You can get more clock cycles out of the F3s apparently for your Gyro and Pid loops. The v1s are probably just fine. I'm just wondering why they put the v1s in the RTF/ARF, but the v2s in the kits.
Oct 06, 2016, 10:48 AM
only with higher KV motors (2600+), which this racer doesn't have
Oct 06, 2016, 12:24 PM
campfir3's Avatar
Thanks for the info.
Oct 06, 2016, 03:26 PM
Reavski's Avatar
Love the form factor to bits, but that maximum upward tilt on the camera looks a bit shallow. Bad design or clumsy photo work?
Oct 06, 2016, 06:43 PM
Ah cheers, Impulse. Knew I'd read it somewhere.
Oct 06, 2016, 10:24 PM
Hi Jim any free samples to offer? I would like to try out the ARF and compare it to my custom built Realacc X210.
