Horten HoXV111
I dont think that this has been posted before
This is Raymond Sonst's design for the 6 engined Horten. He made some concessions to stability, extension tubes on the motors and a very small sub fin underneath. I have no knowledge if either are really necessary. However bungee launching would be tricky without the sub fin. Full details are on the start of the video.
John |
Nice model. Flys well.
You can bungee launch a Horten without the sub fin "handle" by reaching over the wing and wrapping your hand around the nose, then using the other hand to stabilize the tail. 95% of the force is held at the nose. If the root chord is longer than your arm, then it is a no go. The tiny sub fin contributes little to yaw stability. It is so small and so close to the CG. |
Thanks for that John.As Kent says,it flies well.Ive been posting the occasional update from-
http://www.das-nurfluegelteam.de |
