Sep 24, 2016, 01:20 PM
Soaring Fanatic!
8thelephant's Avatar
X1 Touch: Charge on A/C but not on D/C? >>>>>>> Fixed :)
I've been using my X1 for over a year now (both A/C & D/C) and absolutely love it. However, after using it reliably for over 6 months with my DC Power supply, it suddenly gives me the "DC INPUT TOO LOW" error every time I try to charge a battery; regardless of the cell count or capacity.
When I switch back to the A/C plug, things work just as before.
The power supply is a TP1527PS and is also powering TP820CD without any problems. I've also done the following to no avail:
1. Powered only the X1 on power supply and charged a batt (same error)
2. Tested voltage on both power supply ports while charging (15.05V continuous but X1 shows error after 3 min.)
3. Tested voltage from wires going into X1 and TP820CD with no load (15.05V)
Is there a fuse or something internal that could be causing the error?
Sep 26, 2016, 11:20 AM
Team Hitec, Customer Support
Xpress..'s Avatar
There is no internal fuse, can you try the charger out on a 12v automotive battery just to test it?
Latest blog entry: Weekender Warehouse
Sep 26, 2016, 02:07 PM
Soaring Fanatic!
Thanks for the suggestion. I have managed to do a test as requested and as you can see by the photo, the results are the same.
Sep 27, 2016, 10:37 AM
Xpress..'s Avatar
The charger may be damaged then, it would need to be sent in for inspection. Where are you located?
Sep 27, 2016, 11:43 AM
Soaring Fanatic!
Not to far from Poway. I've sent you a PM
Oct 14, 2016, 02:22 AM
Soaring Fanatic!
A big Thank You to Xpress.. and Hitec. I was able to send out the X1 Touch and received it repaired in a couple of weeks. Works great now
-8th
