ImmersionRC Tramp HV - VTX - RC Groups
Sep 23, 2016, 02:00 PM
nitbeat's Avatar
New Product
It's the latest VTX by ImmersionRC, designed for FPV & drone racing.
Very small and light weight and supports 4S direct voltage, as well as 5v.
ImmersionRC Tramp HV 6-18V 5.8GHz 1mW to>600mW Video Transmitter
http://www.banggood.com/ImmersionRC-Tramp-HV-6-18V-5_8GHz-1mW-to600mW-Video-Transmitter-International-Version-p-1088990.html
General Info & Tips
  • According to the manual, you should power the VTX directly from VCC (Battry Voltage, and not via Regulator)
  • Pinout: Battery In, Gnd, +5V Out, Video, Audio, Telemetry (twin grounds on harness)
  • Telemetry: could be used in the future, maybe to control setting via flight controller & Transmitter
  • You can get the cleanest video by powering the FPV Cam using the built in +5v output from the TRAMP
ImmersionRC Manual
http://www.immersionrc.com/?download=5016
Product Page
http://www.immersionrc.com/fpv-produ...o-transmitter/
How to Modify TrampHV VTX Settings Using FRSKY TARANIS menu
Guide Link -> http://www.nitbeatfpv.com/tramphv-un...ttings-taranis
Quick Demo Video: https://www.facebook.com/NitBeatFPV/...9076179291831/
Overview Video:
Modify IRC TrampHV VTX Settings using FRSKY TARANIS Menu (5 min 59 sec)
You can also use android app called PIDFLIGHT VTx and OTG cable to change settings
Change TrampHV VTX settings using Android APP & OTG cable (1 min 20 sec)
Specification
Dimensions: L=32mm x W=14mm x H=5mm
Weight: 4g (Tx only, without SMA cable)
Power Output: Programmable, 1mW to > 600mW
Channels: 48 standard, arbitrary using race wand
RF Impedance: 50 ohms
RF Connector: U.FL
AV Connector: JST-GH, 6 pin, locking
TNR Connector: JST-GH, 4 pin, locking
Audio: Mono, Subcarriers on 6.0 and 6.5MHz (cloned)
Modulation: FM, Audio and Video
Pit Frequency: User/Race Organizer Definable
Video Impedance: 75 ohms
Power Requirements: 2s-4s HV Lipo
Power Consumption: ~4W max. @ 600mW, ~1.9W @ 200mW
Features
– Smallest direct LiPo powered VTx in the business.
– TNR Touch-free wand control
– Traditional button + LED control of frequency and power
– 1mW -> 600mW linear power control
– All 40 standard channels
– Built-in thermal protection
– Factory power normalization
– Glitch-Free frequency changes
– Micro-power pit mode
– Additional channels for race events (Race Wand only)
– Retail regional locking without opening package
[Update]
%8 off - Try Coupon Code: toysho
The personal edition of the Magic Wand, make it easier to change VTX settings,
works even when the vtx turned off.
ImmersionRC TNR Touch N Race Wand NFC programmer for FPV Transmitte
BG LINK: http://www.banggood.com/ImmersionRC-TNR-Touch-N-Race-Wand-NFC-programmer-for-FPV-Transmitter-p-1097726.html
This magic TNR(Touch N Race) wand, enables a quick frequency change of the ImmersionRC Tramp VTX.
One of the coolest things about this system is that you can check your frequency, set a new channel, change the output power level,
all without applying power to your quad, so you wouldn't interfere with other FPV pilots.
If you take part in Race Events production, it will help managing the frequencies during the racing competitions.
Sep 24, 2016, 11:19 AM
yes but when will it ship? Some retailers taking preorders but not many
Oct 09, 2016, 04:46 PM
nitbeat's Avatar
Yeah, it's still on: "Coming soon"
Oct 22, 2016, 06:05 AM
nitbeat's Avatar
Update
The magic Touch N Race Wand has just been added to BG.
Oct 24, 2016, 01:18 PM
Hi Guy's, in the manual it says do not run the tramp from a 12v Source. I'm wondering why?
Verzonden vanaf mijn iPhone met Tapatalk
Oct 24, 2016, 01:32 PM
nitbeat's Avatar
Powering the Tramp
DO NOT power the tramp from a 12V regulator on a 4s powered quad, such as a Polulu.
They mean don't power from an external regulator.
Just power directly from your Lipo, eighter it's 4S or 3S, doesn't matter.
Have fun
Nov 02, 2016, 02:40 PM
I'm curious: I'm flying a rig with a HubOSD from Matek that I'd really like to keep when upgrading my vtx from 13 chinacrap to a tramp.
Anyone have any idea how to set that up?
I see there's apparently two ground wires for the camera and something about ground loops in the instructions.. does an OSD even need the ground connected to it?
Nov 02, 2016, 02:53 PM
RadianceNL's Avatar
My guess would be to connect it to a VCC on the HubOSD and the leftover ground cable to the ground for the camera on the HubOSD.
Connecting that second ground cable to the OSD keeps the OSD from blinking or going a way when you have voltage spikes.
If I'm incorrect please say so, I don't have the Tramp but I do have the HubOSD.
Nov 06, 2016, 01:40 PM
Why does the product description say the Tramp supports a 5V input, since if I connect a ~5.2V source, the VTX doesn't power up?
Is it OK to use the 12V switched power supply from my PDB if I am using a 5s lipo? What other choice do I have? I currently have it connected to a (filtered, Cleanflight OSD/PDB) 12V supply and it seems to work fine.
Thanks.
Nov 08, 2016, 09:11 PM
nitbeat's Avatar
[UPDATE] The Tramp HV is finally in stock and available for purchase...
Thanks.
I guess it will work, but ImmersionRC has mention that it is less recommended that way.
If you have 5S, what can you do, I see no choice but to use a voltage regulator.
Nov 09, 2016, 02:17 AM
pumuklis's Avatar
I can download instructions for use internet?
Nov 09, 2016, 03:21 AM
nitbeat's Avatar
[QUOTE=nitbeat;36154680][UPDATE] The Tramp HV is finally in stock and available for purchase...
Originally Posted by SlyX
I've mentioned that already
Nov 09, 2016, 03:51 AM
I mean that today it's In stock, not in "coming soon".
Nov 09, 2016, 12:08 PM
nitbeat's Avatar
ImmersionRC Manual
Product Page
