This thread is privately moderated by Spaaro, who may elect to delete unwanted replies.
Sep 22, 2016, 04:07 PM
Spaaro's Avatar
Build Log
Vacuum bagging takes a Step Forward!
Finally scored some necessary additions to my bagging set-up:
-A gauge, down to -30 mm Hg... $8 bucks!
-A proper-sized & ported, brass 'Tee'...to accommodate it and the compression fittings that accept my tubing size...$4 bucks.
At least 3 bags I can run simultaneously. Now to actually clear table space for dedicated resin & 'lay-up' prep, instead of shuffling my sundry 'junk' around with each task!
After having read thru the "Electrifly/Great Planes 'deHaviland Tiger Moth" thread from 2010 - 2014, I see it was a kit prone to brittle foam fractures!
Mine happens to be immaculate, but I've reviewed how its flight handling tolerates 'weight gain' well.
I want to give it's thin, undercambered wings some CF spars and a 'veil-weight' glass cloth-skinning...along with the fuse and tail.
This to fly it outdoors and mod it for disassembly the way others did.
Anyone have a direct link to 'light glassing' tips for micro-size planes?
