FrSky Taranis with OpenTX 2.0 (Take 2) - RC Groups
Sep 22, 2016, 08:56 AM
TrueBuld's Avatar
Since FrSky Taranis with OpenTX 2.0 and beyond has just been closed I've created this for now.
As Jim Taylor has pointed out the closed thread is at https://www.rcgroups.com/forums/show....php?t=2178865
Sep 22, 2016, 09:03 AM
TrueBuld's Avatar
Thanks pmackenzie...
You are correct I'm trying to reduce wing rock.
I realise I cannot use a curve in the Weight()
I have got part the way there by using in each aileron section (left and right)
Elevator channel Weight(+25%) flight mode (spoiler) switch (!SC up-arrow) Curve(8)
Curve 8 is a Symmetrical f(x)=-f(-x) curve with a very flat middle section elevator has very little effect round small movements of the elevator stick.
I just need to load the Weight(+ with a value from S2)
My brain is hurting trying to add the value of s2 into the Weight() section of the mix.
The is a guy on a soaring site that does some stunning mixes complete with documentation; however, it is beyond my understanding.
Lost the full link; however, here is a link to the site http://rc-soar.com/opentx/
Sep 22, 2016, 03:18 PM
Here is a link to the original 2.0 thread (which is now closed) for those wishing to search it:
The first few posts include information about 2.0 and a table of contents of links to interesting posts.
I would also suggest that even though the title says 2.0 and beyond, if your question or information only applies to 2.1 you use the 2.1 thread as it will cause less confusion.
Jim
